vibrating when accelerating, why?
Old Feb 16, 2006 | 03:10 PM
VTECcnIT's Avatar
Default vibrating when accelerating, why?
vibrating when accelerating, why? is mmy tires are bad or axles puttn in poorly, bad alignment, or bad tires? it vibrates when i floor it on 1st, 2nd, 3rd
Old Feb 16, 2006 | 03:14 PM
RTW DC2R's Avatar
too much vteck?
wheel hop?
tires bald and unbalanced?
missing wheel weights?
Old Feb 16, 2006 | 03:37 PM
VTECcnIT's Avatar
Default Re: (RTW DC2R)
Old Feb 16, 2006 | 03:44 PM
Eddiebx's Avatar
if it only shakes when you are on teh gas, and stops when u let go, its mostly likely ur axles. or in more rare cases a bad differential or differential carrier bearings
Old Feb 16, 2006 | 06:37 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">too much vteck?
wheel hop?
missing vocabulary?</TD></TR></TABLE>
Old Feb 16, 2006 | 07:33 PM
totsie7944's Avatar
Default Re: vibrating when accelerating, why? (VTECcnIT)
?...... It didn't really make too much sense... but I was thinking wheel hop. I wonder what he has done as for modifications? Could be a number of things.
Does it accelerate with power? or is it sluggish and vibrating... could be a spark problem.
Old Feb 17, 2006 | 08:54 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: vibrating when accelerating, why? (totsie7944)
Could be something as simple as crappy and/or bald tires.
Does this only happen when you accelerate HARD, hard enough to lose traction, or does it happen ANY time you accelerate?
Old Feb 17, 2006 | 11:24 AM
SpeedRacer00-667's Avatar
if its only on acceleration it the axles. when you get off the gas it stops.
Old Feb 17, 2006 | 02:49 PM
tommymoose's Avatar
Default Re: vibrating when accelerating, why? (SpeedRacer00-667)
It could also be worn engine mounts. Some 30 dollar energy suspensions inserts fixed that problem on my old GSR.
Old Feb 17, 2006 | 04:44 PM
Mires's Avatar
Default Re: vibrating when accelerating, why? (tommymoose)
Mine does the same thing just a little bit but it also vibrates just driving at 60 and above. Ive replaced tires, an axle, shocks, and had like 2 alignments all in the past year and has yet to improve. I was told by a Honda tech that it could have something to do with a steering component but haven't had any of that checked out yet. I hope you figure it out.
Old Feb 17, 2006 | 05:31 PM
VTECcnIT's Avatar
Default Re: vibrating when accelerating, why? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">Could be something as simple as crappy and/or bald tires.
Does this only happen when you accelerate HARD, hard enough to lose traction, or does it happen ANY time you accelerate?</TD></TR></TABLE>
yes, only vibrates when i accelerate hard. feels like i lose traction when i hit the high rpms. im thinking either my tires or axle. and or alignment 2
Old Feb 17, 2006 | 05:35 PM
VTECcnIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedRacer00-667 &raquo;</TD></TR><TR><TD CLASS="quote">if its only on acceleration it the axles. when you get off the gas it stops.</TD></TR></TABLE>
in this case if it is my axle, will it vibrate even when im just driving normally and shifting at 3k? my car drives smooth but only vibrates when i punch it
Old Feb 17, 2006 | 06:30 PM
tommymoose's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECcnIT &raquo;</TD></TR><TR><TD CLASS="quote">
in this case if it is my axle, will it vibrate even when im just driving normally and shifting at 3k? my car drives smooth but only vibrates when i punch it</TD></TR></TABLE>
I could almost promise you its worn engine mounts.... You feel it most when you give it alot of gas, no matter what gear you're in.
Old Feb 17, 2006 | 06:34 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">I could almost promise you its worn engine mounts.... You feel it most when you give it alot of gas, no matter what gear you're in.</TD></TR></TABLE>
Mires you should check this out too... it'd be a cheap fix if that was infact the problem
Old Feb 18, 2006 | 02:29 PM
VTECcnIT's Avatar
Default Re: vibrating when accelerating, why? (JUN.R)
i find a great deal on energy suspension motor mounts.. should i buy em to see if they fix my problem or should i buy the motor mounts?
Old Feb 18, 2006 | 08:20 PM
Mires's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">Mires you should check this out too... it'd be a cheap fix if that was infact the problem</TD></TR></TABLE>
Is there a way to check if they are bad?? They look perfect to me. No cracks or anything but I haven't inspected them really close or anything. My R does have about 145,000 miles on it though but I don't know how long they usually last.
Old Feb 18, 2006 | 08:37 PM
JjuuN R's Avatar
take one off, inspect it, if it looks to be ok... then re-install it, then move on to the rest doing it the same way...
if you see 1 is bad or cracked in any way replace the inserts on all of them
Old Feb 18, 2006 | 10:09 PM
tommymoose's Avatar
Default Re: (JUN.R)
After 145,000 miles, yours definately wouldn't be in good condition. Even if they are, its a good mod that costs $30 dollars and takes an hour to do (unless you feel like sacking up and doing the rear one too which is harrddd). Energy Suspensions says that if your mount is damaged, that you should replace it THEN use their inserts, but I've had no problems using the inserts on busted motor mounts.
Old Feb 19, 2006 | 07:38 AM
RTW DC2R's Avatar
can you shake the motor with your hands?
Old Feb 21, 2006 | 09:59 AM
SilverDc2's Avatar
im having a simliar problem,
i've narrowed it to
wheel bearing,
shock,
motor mount,
i would check your suspension bushing, upper control arms for play,
or even a loose rack n pinion
Old Feb 21, 2006 | 06:46 PM
crazi_E's Avatar
Default Re: (SilverDc2)
thats some text message lol
ujhonda
Oct 17, 2007 12:10 AM
type B16
Oct 31, 2006 07:29 AM
b16a27
Mar 4, 2005 09:18 AM
FULL-RACE EP3
Aug 5, 2004 02:34 PM
Thirty-Nine
Jan 20, 2004 08:12 PM
