The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar
<u>EDIT:</u> For those just skimming thru, please read thru as I was able to get the bar to fit despite my initial post.
Does it fit? Well I found out today.
The answer, is of the worse kind: maybe.
Upon intial drop-in, it will not fit on my car but, there is a slight chance it will drop right in on a car with stock suspension.
Yes the LHD firewall has threaded holes that will support the firewall bracket.
However, the studs on my Tein HA pillow mounts are too long, and will not allow the holes in the bar to line up.
I looked at my stock struts and I think the studs are significantly shorter. There is a slight chance the bar will fit (It will be close) with a stock suspension. I could cut the studs down a bit, but first I will try on a friends stock susp car.
As a note, the harness bracket that mounts to the left tower needs to be moved, as well as the sensor bracket on the firewall right above the IM (what sensor is this? MAP?)
As for master cylinder clearance, assuming the studs can get thru the holes on the bar, it will be damn close, with the bar coming right down above the cap.
Modification to make it fit may include the following:
-Slot mount holes on the bar a little.
-Shorten studs on struts.
-Remount or secure sensor, harness and lines.
This is all assuming it will clear the MC Cap, which would be very difficult to modify
I apologize I didn't have my camera on me, but when we try on a stock itr, I will take some pics (Will try at the track tonight)
More info to come.
-sack
[Modified by sackdz, 5:14 PM 5/21/2002]
[Modified by sackdz, 4:38 PM 8/6/2002]
More info to come.
-sack
Re: The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar (AssPenny)
i bet just like the Cusco MC brace u can hack around to make it work
le - who likes to see one of these bad boys in person
Re: The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar (vtecvoodoo)
i will steal it from sack tonight and put that biatch on ebay, keep a look out tomorrow!!!
Re: The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar (owen_the_soyboy)
i wonder if it woudl fit my car.
take pics of how it doesnt fit
Re: The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar (Willard)
Well I haven't tested in on a stock R yet, I know everyone is waiting, sorry
But it's all good because there will be 500+ stock R's at the expo S00nday, and I'll be sh0 to bring up the shiny Al-You-Minnie-uhm specimin for everyone to see and touch and pet and fondle and try to fit on their car.
Stay tuned.
Stay tuned.
Re: The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar (sackdz)
Can I touch? I won’t make a mess.
I think that if the bar is placed on the car and then the shock are raised into position (then bolted up)… the forward fitment points will work out ok.
The relocation of the 'sensor' on the firewall is no big deal.
The brake fluid reservoir is a big deal.
Will
Will
Will
Will
EDIT: I'm able to get the bar on and off in 10 minutse now.
[Modified by sackdz, 4:39 PM 8/6/2002]
Will for $55, I'll let you have it alone in a room for 30 minutes
Um, to me the need to drop your shocks everytime you take the strut tower bar on or off is not kosher- what a pain in the ***.
The install should only be done one time..
once it is on... it will stay.
Willis
-who loves the weld quality... and the price.
but having to remove it everytime I flush brake fluid would suck ***....
will
-who will have to get better fluid...
will
I think a bar like that would be more effective if they made it so that it braced the upper control arm bolts the firewall, instead of the upper shock mounts, since the upper control arms is what takes the direct cornering loads, not the shocks.
But you gotta remove the bar to do things such as switch intakes, and um, lots of other things that I can't think of right now.
IT FITETH!
I ran the bar for the entire expo.
It turns out that you only need to drop the shocks for installation. jack the car up after unbolting the uppoer mount, and it fits.
THe other modifications are:
-Bend the passenger side wire harness bracket top flat up 90 deg.
-Remove solenoid bracket on firewall. I just left it underneath the bar, it's pretty snug.
-Bend down the hose arm on the fuel filter bracket.
Like so:
As for performance...
Sorry! I dunno. I'm still getting used to the new suspension and R compound tires, and z-10 bars on the track so i don't know!
But the car felt damn good! Ask the expo folk who got rolllllllllled by #124
[Modified by sackdz, 7:33 PM 5/29/2002]
[Modified by sackdz, 7:34 PM 5/29/2002]
Like so:
Re: The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar (Jordo)
sweet, will the stock bar fit over it?
? i thought it was a replacement for the stock bar....
Re: The Verdict: Fitment of Type II Carbing JDM RHD Strut Tower Bar (Brian Spilner 1035)
i remmeber in the pic...
just a thought
[Modified by Jordo, 7:30 PM 5/29/2002]
just a thought
