Vafc Question
Old Dec 1, 2002 | 12:54 PM
BRICKHEAD's Avatar
Default Vafc Question
I recently installed a Vafc in my 01 R and my vtec does not seem to be kicking in. I was wondering if there is a way that maybe it is turned off through the vafc. I did a search and read the directions but they are very vague on what to do. On the one screen it says that VTi is off, could this be my problem? Any help would be great.
Old Dec 1, 2002 | 01:00 PM
typeR00-0005's Avatar
Default Re: Vafc Question (JDM-R)
no you leave that off.vti on off. when i hooked my v-afc i had the same
problem it wouldn't engage. i didn't hook up the vtm wire double check
to make sure all the wires are hooked up.
Old Dec 1, 2002 | 01:01 PM
rainmanEK's Avatar
big strong guy
Default Re: Vafc Question (typeR00-0005)
Whats wrong with hooking up the VTM wire?
eric
Old Dec 1, 2002 | 01:18 PM
BRICKHEAD's Avatar
Default Re: Vafc Question (rainmanEK)
Any other possibilites before I rip the ecu out, settings etc...
Old Dec 1, 2002 | 01:25 PM
sneakychaos's Avatar
Check all the wires and make sure they are together fine. Did you solder or did you just tap into the wires? Did you make sure you got the wires touching and not the rubber. 99% of the time its the install.
Old Dec 2, 2002 | 06:23 AM
CRiSP's Avatar
Default Re: Vafc Question (sneakychaos)
also make sure you have it set to 6 sensors.
darkjedi022
Feb 5, 2004 05:52 AM
216.226.142.95:27016
Dec 13, 2003 12:50 PM
vaporboy12
Dec 8, 2003 05:36 PM
emissionsux
Sep 4, 2003 01:23 PM
