V-AFC Setup Help Needed ASAP
Old Nov 30, 2001 | 03:11 PM
onyx00's Avatar
Default V-AFC Setup Help Needed ASAP
Okay, need some quick help on V-AFC install. Got it installed, just the initial settings need help with:
1.) How many sensors? It asks for sensor numbers; the default is 6 in and 6 out.
2.) What throttle setting? The default is an up arrow (choices are ** and a down arrow).
Anything else I need to do for initial setup!?
ANY HELP GREATLY APPRECIATED!!!
Thanks!
Old Nov 30, 2001 | 03:53 PM
onyx00's Avatar
Default Re: V-AFC Setup Help Needed ASAP (onyx00)
Worthless, everyone in here is worthless!!!!!!! j/k
I disconnected it; figured I will hook it up when I get a dyno tunning session set up.
Old Nov 30, 2001 | 03:57 PM
TodaCivic's Avatar
Sensors 6 in and 6 out.
Throttle arrow up and to right.
# of cyl's 4
That should get you started ...then hit intialize.
Im me if have any more questions.
Please DON'T mess w/ fuel till get on dyno to tune.
LATA
Old Nov 30, 2001 | 05:13 PM
JoshRambo's Avatar
Default Re: V-AFC Setup Help Needed ASAP (TodaCivic)
I don't think you have to intialize anything. if you select that it puts all of what you set to the factory defaults. i did it on mine and it set it to be a 6 cylinder with out me knowing. so i assume that 6 cylinder is a default.
Old Nov 30, 2001 | 06:09 PM
onyx00's Avatar
Default Re: V-AFC Setup Help Needed ASAP (Gravity)
Yeah, I got it running, but the car seemed to be running rich. I figured no point in keeping the thing hooked up until I get it dyno tuned.
I have a harness from Kenji, so connecting and disconnecting it makes things very easy.
sir2sol
Apr 16, 2006 05:46 PM
smkngsr
Apr 11, 2005 05:58 AM
DB8
Jun 14, 2002 12:40 AM
azntyperrr
Nov 12, 2001 08:11 PM
