type r sitting for a while
Old May 21, 2006 | 08:04 PM
Speed Infliction's Avatar
Default type r sitting for a while
My car has been sitting for about a year and a half and I change out the gas and dropped some oil down in the cylinders. Anybody have any other suggestions that i should do. Thanx
Old May 21, 2006 | 08:12 PM
Kavehman's Avatar
change the oil before you start her up, let it drain nicely and then start it up.
Id also make sure the throttle body is clean.
Old May 21, 2006 | 08:49 PM
Haleiwa-Brando's Avatar
Default Re: type r sitting for a while (Black Mamba)
Give all the fluids a good once over. Does the battery have 12V? If you hear anything wierd shut her down until you can figure it out.
If you drive it, take it slow and if your confindent put a few miles on the car to get it warmed up and all the fluids properly circulated and what not. Your tires could be out of round as well.
Old May 21, 2006 | 10:18 PM
MilFhunter001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black Mamba &raquo;</TD></TR><TR><TD CLASS="quote">My car has been sitting for about a year and a half and I change out the gas and dropped some oil down in the cylinders. Anybody have any other suggestions that i should do. Thanx</TD></TR></TABLE>
I never heard of someone dropping oil down the cylinders before. How do you do this and why?...
Old May 22, 2006 | 11:08 AM
jep's Avatar
jep
i have heard of dropping oil in the cylinders, but only on rotary motors to build compression. :s
Old May 22, 2006 | 12:47 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (jep)
You can take out the plugs and drop a cap full of ATF down into the cylinders. This will help lube them up so the cylinders dont scar. Also if the rings have dried up, the atf will lube everything up.
Old May 24, 2006 | 11:11 AM
Default Re: type r sitting for a while (Haleiwa-Brando)
I appreciate all the advise. The car is running like it did a year and a half ago. Honda is such great quallity. I don't think any domestics motors would have done the same.
Spec R
33
Oct 28, 2007 07:45 AM
lalaine17
Apr 13, 2006 01:51 PM
EKcivic1230
26
Jul 7, 2005 07:19 AM
type-r 01 886
Jan 4, 2005 11:34 AM
accordselux
Aug 15, 2004 05:31 PM
