Type r heater problem
Old Mar 11, 2011 | 11:52 AM
David27's Avatar
Default Type r heater problem
I bought a 2000 type r about a year ago I took out the motor to rebuild and the heater worked fine, so I put a b16 in the car just so I could still cruise it around, after I put the b16 in I have no heater, when I go from 1 to 4 I get nothing and none of my heater options light up when I push them but they will light up when I have running lights on so climate control has power to it. If anyone has experienced this or have any ideas that would be great thanks.
Old Mar 11, 2011 | 11:55 AM
Ultraspeed DC2's Avatar
Default Re: Type r heater problem
Is the cable still hooked up? Did you bypass the hoses at the motor before it went into the car instead of hooking them up at the firewall?
Old Mar 11, 2011 | 12:01 PM
David27's Avatar
Its weird heat still comes through the vent while I'm driving but there is no way I can control it or stop it from coming in and no hoses where by passed I guess I could pull the climate control and look but I don't see why it would come undone. Thanks for the fast response
Old Mar 11, 2011 | 12:27 PM
Tyrant_007's Avatar
Are both coolant hoses hot? And is the coolant topped off? Might be dumb things to check, but sometimes the basics get overlooked.
Old Mar 11, 2011 | 01:35 PM
David27's Avatar
yea hoses are hot and coolant level is fine idk how that relates to the heater switch not working but thank you for the reply.
Old Mar 11, 2011 | 02:36 PM
Is your thermostat in there or does it work?
Make sure that cable on the firewall for the valve is moving.
Old Mar 11, 2011 | 03:52 PM
Tyrant_007's Avatar
LOL, pardon my failure to read. My brain is fried. TGIF! :facepalm:
Might check the 40 amp (under hood) heater motor relay or 7.5 amp (under dash) Heater blower rly fuse though....I hope I didn't get those confused.
Old Mar 11, 2011 | 08:04 PM
Quick99Si's Avatar
Soichiro Honda say: you put B16 in Integra Type R, you no get heet!
Old Mar 12, 2011 | 01:37 AM
David27's Avatar
lol no problem I checked the 7.5 and it was good ill check the other one tomorrow and yea the type r is probably pissed at me because of the b16 lol, but I hate seeing it in the garage when its sunny and I cant take it out ill probably put the motor back in and everything will work lol
Morasso
Dec 16, 2007 11:03 AM
jadugartir
12
Nov 10, 2006 10:18 AM
Boostage
Jun 18, 2006 07:49 PM
zerogravitycrx
Dec 6, 2004 01:34 AM
