Turbo causing speedometer prolems??
Old Oct 1, 2002 | 10:06 PM
R-1303's Avatar
Default Turbo causing speedometer prolems??
when i hit vtech after installing my turbo kit, the needle bounces everywhere!! from like 30-120mph!! but when i'm full on racing it sits at 0..can anybody evaluate??
also: I installed a ecg perfamance electronics o2 simulator...if that adds to the problem.
Old Oct 1, 2002 | 10:07 PM
B2FiNiTY's Avatar
Default Re: Turbo causing speedometer prolems?? (R-1303)
It's VTEC.
Rob :190:'s Avatar
thats cause you're so fast now.
actually, that shouldnt happen, check anything you messed with wiring wise when you installed the snail
Old Oct 1, 2002 | 10:08 PM
TypeR 599's Avatar
hey mark, does your engine say "vtech?" . just ******* with you.
yeah his gauge is weird...get into second and BAM you're going 120 at 6k. probably the G's your turbo R pulls threw it off...
Old Oct 1, 2002 | 10:18 PM
ZygSpeed's Avatar
Default Re: Turbo causing speedometer prolems?? (TypeR 599)
Check the VSS signal or the fuse for the secondary O2 sensor, ...
Old Oct 2, 2002 | 04:17 AM
NunRacer's Avatar
Default Re: Turbo causing speedometer prolems?? (Zygspeed)
if only the car actually did that 30-120 in the blink of an eye
Old Oct 2, 2002 | 04:01 PM
TypeR 599's Avatar
Default Re: Turbo causing speedometer prolems?? (NunRacer)
the tach does atleast. haha
TTT for the baddest McD's R
Old Oct 2, 2002 | 05:35 PM
ryu12341's Avatar
my tach kinda had the same problem, it would bounce from 20 km to 50 km. I found out that it was from a burnt out fuse to the alternator. check your fuses
Old Oct 2, 2002 | 06:05 PM
R-1303's Avatar
Thanks guys..i'll check it out this weekend hopefully it works out well.
rhdune16
Nov 26, 2005 09:33 AM
the.hamburglar
Jun 12, 2005 03:47 PM
R-1303
Oct 2, 2002 06:35 AM
R-1303
Oct 2, 2002 02:34 AM
