Trying to do a compression test
Old Jun 17, 2003 | 03:30 PM
Nate B's Avatar
Default Trying to do a compression test
But I can't seem to find a break down in my helms manual for the steps needed. And C-Speed doesn't have the link available anymore either. Can anyone let me know where in the helms manual the compression test is broke down? I've pretty muched looked through the whole thing and I know it's gotta be in here somewhere. Thanks guys
Old Jun 17, 2003 | 03:33 PM
len's Avatar
len
Default Re: Trying to do a compression test (Nate B)
Here is how I did mine.
I bought a $25 compression tester at some parts store.
Remove all the sparkplug wires and sparkplug.
I then unlplugged all the fuel injector harness.
I started from cylinder one and ended at cylinder four.
On each one I did about 7 cranks and wrote down the numbers.
HTH
Old Jun 17, 2003 | 03:54 PM
Nate B's Avatar
Default Re: Trying to do a compression test (len)
Thanks Len, I know the basic routine, But I was just curious and almost positive that the procedure was shown somewhere in my Helms and was just trying to find it. Thanks again
Old Jun 17, 2003 | 04:35 PM
Evs-One's Avatar
Solbros Owns Me
only do 5 cranks...anymore than that is almost a waste of cranking...lol.
Make sure your throttle is wide open also.
Old Jun 17, 2003 | 05:38 PM
cheezthis's Avatar
Default Re: Trying to do a compression test (Emerika)
http://www.c-speedracing.com/h...t.php
Works for me...
You should have said this at the bbq, I had a tester in my back seat.
Old Jun 17, 2003 | 06:13 PM
Chubz's Avatar
Default Re: Trying to do a compression test (cheezthis)
u dont have to remove the harness, you need to remove the Fuel Injection fuse in the fuse box, if you dont you can fry the ignitor in the distributor
Old Jun 17, 2003 | 06:20 PM
Nate B's Avatar
Default Re: Trying to do a compression test (B18CR01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CR01 &raquo;</TD></TR><TR><TD CLASS="quote">u dont have to remove the harness, you need to remove the Fuel Injection fuse in the fuse box, if you dont you can fry the ignitor in the distributor</TD></TR></TABLE>I did, 15A pulled from upper left corner of fuse box
civic_driver
23
Jun 12, 2009 07:55 AM
boosted92hatch
Feb 21, 2008 11:07 AM
RRRex
Apr 19, 2005 01:55 PM
bluemex
Aug 14, 2003 12:13 PM
sCeRaXn
Oct 9, 2002 04:43 PM
