Trunk problems
Old Nov 17, 2004 | 05:35 PM
ilovemydc2's Avatar
Default Trunk problems
i have a strange squeaking in my trunk and or something in the rear of my R. Anybody have a similiar problem?
Old Nov 17, 2004 | 05:49 PM
Chris F's Avatar
Default Re: Trunk problems (ilovemydc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemydc2 &raquo;</TD></TR><TR><TD CLASS="quote">i have a strange squeaking in my trunk and or something in the rear of my R. Anybody have a similiar problem?</TD></TR></TABLE>
That sucks. Could be a LOT of things. Suspension bushings, loose spare tire (rubber on sheetmetal squeak), interior plastic panels, exhaust, etc. Hopefully it's superficial.
-- When do you hear the squeak? Bumps? Cornering? Idle?
-- Can you find a small passenger to wander your trunk while you drive and make the squeak happen?
-Chris
Old Nov 17, 2004 | 05:51 PM
Bbasso's Avatar
Default Re: Trunk problems (ccfries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfries &raquo;</TD></TR><TR><TD CLASS="quote">That sucks. Could be a LOT of things. Suspension bushings, loose spare tire (rubber on sheetmetal squeak), interior plastic panels, exhaust, etc. Hopefully it's superficial.
-Chris</TD></TR></TABLE>
Hahahah I had to clime in there recently, and let me tell you, there is nothing to hold on to, and I was getting bumped around- even slow driving. But I did find the noise I had
I say check two things the brake lights and the filler panel below the brake lights, they have gaskets and maybe they wore out.
Old Nov 17, 2004 | 06:56 PM
Utilitarian's Avatar
Mine starting doing the same thing about 5k miles ago.
Solution: turn music up
Old Nov 17, 2004 | 07:39 PM
Jason's Avatar
Default Re: Trunk problems (Utilitarian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Utilitarian &raquo;</TD></TR><TR><TD CLASS="quote">Mine starting doing the same thing about 5k miles ago.
Solution: turn music up </TD></TR></TABLE>
You still have speakers in your R?
Old Nov 17, 2004 | 07:54 PM
Mugen Mike's Avatar
I'd be willing to bet $10.00 that its the clips that hold the plastic trim panel to the underside of your hatch. Try pressing on it and see if you hear the squeak. Some electrical tape wrapped around the metal clips that hold it in place took care of it for me.
Old Nov 17, 2004 | 07:56 PM
.RJ's Avatar
.RJ
Default Re: Trunk problems (Mugen Mike)
I heard a squeek right before a suspension bolt snapped on track in my 91 integra.
Look everything over.
Old Nov 18, 2004 | 08:32 AM
mstewar's Avatar
when the bushings on the rear swaybar are worn, it will often make a squeek.. check the suspension bolts, check the bushings.. if nothing is wrong, it might just be an interior panel..
Old Nov 18, 2004 | 09:16 AM
Philly_NBP_R's Avatar
Default Re: Trunk problems (mstewar)
I have a similar problem with my R...
THE ENTIRE F'N CAR SQUEAKS AND RATTLES!!!
Honda = rattletrap... just get used to it
Old Nov 18, 2004 | 09:20 AM
ebelp's Avatar
Default Re: Trunk problems (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">I have a similar problem with my R...
Honda = rattletrap... just get used to it </TD></TR></TABLE>
Exactly. Just turn up the volume on the radio...it'll go away.
Old Nov 20, 2004 | 04:29 PM
wanna b R's Avatar
Default Re: Trunk problems (ebelp)
i have the same problem
slowB20ej8
Paint and Body
Jan 24, 2008 05:41 PM
CRX MASE
Sep 1, 2007 05:50 PM
chriseg6
Honda S2000
14
Aug 5, 2006 06:22 AM
fujii13
May 4, 2005 09:30 AM
