trunk light
Old Jun 19, 2001 | 04:30 PM
itr0032's Avatar
Default trunk light
Has anyone had any troubles with their trunk lights coming on and remaining on even when the trunk is clearly closed tightly?
Old Jun 19, 2001 | 04:55 PM
Bob#455's Avatar
Default Re: trunk light (itr0032)
There should be a switch on the light that is a little tempermental at times. If you put it in the "off" position, and very slowly move it, you will notice that there is a halfway point that comes before the full "on" position. This will turn off the light when you close the hatch, but turn it on when it's open. Hope this helps.
Old Jun 20, 2001 | 10:16 AM
itr0032's Avatar
Default Re: trunk light (Bob#497)
I'm taking about the one on the dash...the little red car with the truck up.
Old Jun 20, 2001 | 10:58 AM
Splat's Avatar
Collector-o-Guns and Drinker
Happened on my roommate's '99 GS-R for the door switch. Take it to the dealer and beat them about the head and shoulders until they fix it.
Old Jun 20, 2001 | 11:44 AM
NewYorkTypeR's Avatar
New User
Default Re: trunk light (itr009)
I had this problem on my r at first they said that it was something electrical but ofcourse they were wrong and the **** would only go on when I wasn't at the dealer. So I brought it back and it turned out the trunk latch was bad and they had to replace it.
Old Jun 20, 2001 | 01:50 PM
timberwulf's Avatar
Default Re: trunk light (73rd 2000 ITR)
eek man...nice caps.
I always give a firm upward tug on my hatch when I close it to ensure that I got it all the way latched. Does yours move at all when the light is on and you tug it?
Old Jun 20, 2001 | 02:22 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: trunk light (timberwulf)
Yeah, he gets pissed off when you mention it, too.
Good thing his car isn't as ugly as his posts...
Old Jun 20, 2001 | 02:52 PM
itr0032's Avatar
Default Re: trunk light (nsxtasy)
yeah...it's closed, I pulled up as hard as I can.
Old Jun 20, 2001 | 04:07 PM
STOLEN - ITR 98-0652's Avatar
It's the hatch latch... mine stuck closed.
Simple test in Helms... warranty item.
Old Jun 20, 2001 | 04:13 PM
itr0032's Avatar
Default Re: trunk light (ITR 98-0652)
Thanks for all the info,new goes on Wednesday.....Warranty item
Old Jun 20, 2001 | 06:33 PM
t's Avatar
t
. It is alarm related.
Let me guess you have an aftermarket alarm Hood pin? (When they installed your alarm they tagged the hood pin and trunk pin together to trigger the alarm)
You need to readjust the hood pin to make sure the hood pushes the pin down completely
HTH
Old Jun 21, 2001 | 02:42 AM
itr0032's Avatar
Default Re: trunk light (t)
t....I think you are right.I just put on a Carbon fiber hood.The hood pin is not even hitting it...I will go try that.Thanks
Old Jun 22, 2001 | 07:58 AM
imnotagoodtyper's Avatar
New User
other reasons could be....fuel cap not closed tightly, trunk control module, trunk latch , but most probably aftermarket alarm...have the same problem...but you know what...ive noticed if you bring the steering wheel way up...then lean back a little (yes yes almost like the "gangster rice boy look" not quite as far back tho) while your driving...you dont even see it ...but then...its still gona be there haunting you till you get it fixed...hehe good luck
Old Jun 22, 2001 | 11:49 AM
itr0032's Avatar
Default Re: trunk light (imnotagoodtyper)
It turns out to be the hood pin....thanks eveyone
mdh111
Dec 6, 2016 11:40 PM
user 8508202243
Apr 29, 2012 03:33 PM
aspire
Jun 19, 2009 05:19 AM
georgeda
Aug 12, 2003 03:53 PM
The Kegger
Jan 9, 2003 12:10 PM
