Transmission Problems
Old Jan 28, 2011 | 02:15 PM
Rene1123's Avatar
Default Transmission Problems
Hey got a 2000 integra type r. Recently the reverse gear has been acting up on me. Today it got to the point where it dosnt go in at all. All other 5 gears go in just fine. Any suggestions?
Old Jan 28, 2011 | 03:55 PM
FULLYBUILT2.0's Avatar
Default Re: Transmission Problems
Might be a bad reverse gear selecter?
Old Jan 28, 2011 | 03:57 PM
Rene1123's Avatar
uhh help me out here i dont know to much about transmission...
Old Jan 28, 2011 | 05:27 PM
Aquafina's Avatar
Brake stopper ring, synchro, or slider are my guesses. No way to tell though without splitting the trans and inspecting.
Old Jan 28, 2011 | 08:59 PM
tofu1413's Avatar
i had my reverse go on my car..
the syncro for it was basically chewed up... from what i remember, the 5th gear and reverse shared the syncro...
Old Jan 28, 2011 | 09:20 PM
Rene1123's Avatar
but my 5th gear goes right in. can it still be the syncro?
Old Jan 29, 2011 | 11:40 AM
Aquafina's Avatar
5th and R have their own synchros. It will still go into 5th just fine as long as the hub is scratched up.
Old Jan 29, 2011 | 02:03 PM
Quick99Si's Avatar
Simplest things first guys.
Does it go in at all with the engine not tuning? Also it doesn't necessarily sound like your shift linkage or mounts are the problem, which seems to be the case behind most issues on these cars. I suppose it wouldn't hurt checking those over but these are so much easier (though much less likely) that you'd be kicking yourself in the nuts if the culprit was there. Last shot in the dark would be the reverse switch binding for whatever reason. Pray it's one of those because...
Otherwise it's time to remove and open up the trans. I got money on the shift change holder assy (SCHA) or the reverse holder. I've seen this piece bend and eventually break on a few B-series transmissions. It usually fails when the drivers "rows" through the gears and put extra stress on one small component. Conversely, the reverse holder may fail when you keep trying to stuff it in there using a lot of pressure.
If for some reason it's the actual reverse idle gear, PM me your address and I'll send you one.
Old Jan 29, 2011 | 02:19 PM
Quick99Si's Avatar
Take a look at this: https://honda-tech.com/forums/transmission-drivetrain-127/b-series-transmission-teardown-rebuild-tutorial-2443459/
Old Jan 29, 2011 | 02:55 PM
Aquafina's Avatar
When the SCHA bends/cracks/breaks it causes problems in all gears.
I've never seen a reverse switch bind with the switch out (not in reverse), only with it in (in reverse) which will only cause the reverse lights to stay on but not any shifting problems.
Old Jan 29, 2011 | 04:50 PM
Quick99Si's Avatar
Correct, the SCHA will, and while it seems to be more noticeable in 2-4-R than 1-3-5, the reverse component is unique to that gear only. It would be the most likely problem next to the R synchro... both of which obviously require trans removal.
OP, can you even get the car into R while the engine is off? If not, does the car move at all as you're trying to put it in reverse with the engine running? What if you go through the gears with the clutch pedal down, then try reverse?
Old Jan 29, 2011 | 06:35 PM
Rene1123's Avatar
Thanks for all the info. Today it did end up going into reverse but it ends up being very stiff. all the other gears are great. Mounts and shift linkage are good nothing broken there. Not completely sure where the reverse switch binding is. do you perhaps have a picture? i will have to look at that because the kill switch previous owner put on it is hooked up to the transmission. As quick99si said it mostly is the reverse holder due to my impatiens and rowing through gears.
Old Jan 29, 2011 | 07:05 PM
Aquafina's Avatar
Reverse switch is the only electrical connection on the trans other than the VSS.
Old Jan 29, 2011 | 08:29 PM
Rene1123's Avatar
ok so how can i tell if its broken?
Old Jan 29, 2011 | 11:10 PM
Aquafina's Avatar
Your reverse lights either don't work at all or stay on when its not in reverse.
Old Jan 30, 2011 | 02:01 AM
Rene1123's Avatar
lol ok so its not that.
Old Jan 30, 2011 | 10:48 AM
tofu1413's Avatar
funny how my old usdm tranny acted..
it refused to go into both 5th and reverse.. took tranny apart and there was only one syncro that was completely chewed up. (well, that and the gearset itself has its fair share of chipped teeth and discolored gears... the last owner probably never changed the tranny fluid.)
jdelacruz129
Jan 30, 2017 01:36 PM
BigAnteg
Apr 30, 2010 05:03 AM
dornon13
Dec 24, 2007 10:21 AM
singhis
Mar 8, 2006 01:07 PM
