Transient Response Validation
Old Feb 12, 2003 | 07:02 AM
hitechex's Avatar
25 Year Member
Default Transient Response Validation
This is validation for those who scoff at the transient response scenario. Cosworth Engineering has custom built 3 new transient dynos in Northhamptonshire England. As the article reads this is a big step in development for their F1 program.
http://www.racetechmag.com/news/indu...p?id=42&menu=3
Old Feb 12, 2003 | 07:05 AM
Chris N's Avatar
Default Re: Transient Response Validation (hitechex)
Cosworth's "Big Step"
From the desk of Mark Skewis
Cosworth has opened a new dynamometer facility at its Northamptonshire base. Engineering MD Nick Hayes heralds the move as a “big step” for the engine specialist, which supplies three Grand Prix teams. Three new transient dyno cells have been custom-built, rather than Cosworth opting for an off-the-shelf solution. It will significantly boost its F1 capacity, which has, until now, relied on the use of Ford’s Detroit facilities.
That's it?? I was hoping for something more concrete. I.e., description, explanation, purpose, etc.
Chris - who envisions that this thread will become a popular one....
Old Feb 12, 2003 | 07:29 AM
Dr Pooface's Avatar
Default Re: Transient Response Validation (Chris N)
Sooo...what is a transient response?
lol
Tweakmeister's Avatar
it's a start
Old Feb 12, 2003 | 07:39 AM
onyx00's Avatar
Yeah, that article was pretty weak
MrBite's Avatar
Default Re: Transient Response Validation (Tweakmeister)
it's a start
They're going to need more than that to have compteitive F1 engines...
Old Feb 12, 2003 | 07:43 AM
SlapSmak's Avatar
Default Re: Transient Response Validation (MrBite)
the illudium T-36 explosive space modulator was tested on a transient dyno thingy
Old Feb 12, 2003 | 08:21 AM
Austin's Avatar
Interesting...
Old Feb 12, 2003 | 08:23 AM
RR98ITR's Avatar
Default Re: Transient Response Validation (Austin)
What is a Transient Dyno and what does it do?
Well, it measures output against a variable load to simulate actual operating conditions around a racetrack.
Superflow has provided a reasonable explanation of why this is of some importance at http://www.superflow.com/support/sup...el-inertia.htm:
What are acceleration tests and inertia "correction"?
When an engine is accelerating, the torque difference observed during the test is not simply a function of the inertia of the engine/dynamometer combination. The power of the engine actually changes, due to the effects of wall flow and spray flow of the fuel, as it travels down the port to the cylinder. The engine power is also affected by the temperature of the gases in the intake port, the combustion chamber, and the exhaust pipe. These are very different when the engine is accelerating, as opposed to when the engine is running at constant speed. There have been several SAE Papers written about this phenomenon, and the difference is substantial. You cannot simply calculate these factors away with an inertia correction factor.
In fact, the primary reason for running both steady state and acceleration tests is to be able to discern the differences between these effects. If you run an engine test at 100 rpm a second, and then again at 300 rpm a second, you will find an average torque reduction at each test point. This can be easily referred to as the torque required for 100 rpm a second acceleration. A typical number for a small block Chevrolet engine would be 3.5 lb-ft of torque for 100 rpm/sec acceleration. (This number would be for an engine on a SF-901 dynamometer). It is important to note, that this number is a function of the inertia of the engine, plus the inertia of the dyno. SuperFlow dynos have the lowest inertia of all the current dynos on the market and consequently, the dynamometer inertia has the least effect on the total test.
Some competitors measure the rate of speed change between each data point, and then multiply it by an adjustment constant for the engine and dynamometer inertia. There is nothing inherently wrong with this as long as you understand that there is no real-world basis for the result. As acceleration rates increase above the 300 rpm a second rate, as they frequently do in high performance applications, you will find that simply correcting for inertia does not calculate the steady state answer, and in fact gives a substantially different answer, as indicated in the SAE Papers. So, if the answer is not correct for acceleration, and it is not the same as steady state, what is the point in making this calculation? The answer seems to be that it simplifies the explanations you must provide, if your control system does not provide a smooth rate of acceleration, or you are trying to obtain this acceleration by manually controlling the dynamometer.
It appears that this feature does not provide any clear advantage in obtaining new or more accurate information during a test. Unfortunately, people are frequently confused between smoothed data and accurate data. If you are under rapid acceleration and your engine has occasional misses, do you want that smoothed out of your test data?
I'll come back to this later.
Scott, who wonders if John will be bringing legal action against Cosworth....
Old Feb 12, 2003 | 09:06 AM
Johnny Tran's Avatar
Default Re: Transient Response Validation (RR98ITR)
now THATS funny chit
nick, who thinks John should sue everyone that says, "high tech"
Old Feb 12, 2003 | 10:24 AM
SMSP's Avatar
Default Re: Transient Response Validation (George Knighton)
It's a transient dyno. What's in question is the term "transient response" that was coined by Larry and/or John or maybe someone else. I think I already made the point that the two word term is poorly worded since both words mean "change" and it's probably more suited for marketing. The link doesn't use the term response but only transient.
I guess it can be measured after all. No kidding. An engine is a mechanical and electrical device.....output can always be measured. An engine isn't a magical device with non measureable power.
SMSP - Who will also be back to this one.
Old Feb 12, 2003 | 10:37 AM
SurferX's Avatar
Default Re: Transient Response Validation (Johnny Tran)
And this is why serious discussions on here turn into needless name calling and arguing about garbage not even on the subject. Grow up
Old Feb 12, 2003 | 10:40 AM
RR98ITR's Avatar
Default Re: Transient Response Validation (SMSP)
....I guess it can be measured after all. No kidding. An engine is a mechanical and electrical device.....output can always be measured. An engine isn't a magical device with non measureable power.
Yes, but which "it" are you talking about.
Scott, who recall's that Larry's "it" cannot be measured....according to Larry....
Old Feb 12, 2003 | 11:42 AM
Default Re: Transient Response Validation (SurferX)
lol...oh well +1
Sw3d
I B T L
Old Feb 12, 2003 | 11:57 AM
Chris N's Avatar
Regardless if 'transient response' exists or not (which is very ambiguous as SMSP has told us, but we can't find a better term since TR itself has no real definition... yet [not one that is agreed upon]), simply posting a link to a one paragraph article means nothing to me.
So they have a transient response dyno. So what?
I find this thread rather insulting to those that contributed to the other 2 TR threads. Alot of thought, time and effort was put into those threads, regardless of the fact that no consensus was reached and no 'conclusion' on what TR actually measures was found.
That is like me saying "I used a telescope to determine that the universe is 13.7 billion years old." It is rather vague and unprovable by itself. Obivously much more scientific explanations are needed before the above sentence can be determined to be right, wrong or even considered valid and debatable. I think the same idea applies in this case. Give us some TANGIBLE data, explanations, etc.
Looks like the best bet is the article Scott posted. I just don't understand what this thread was supposed to prove.
[Modified by Chris N, 3:01 PM 2/12/2003]
Old Feb 12, 2003 | 12:01 PM
MK Ultra's Avatar
A point that has been overlooked thus far is that Cosworth will be using this equipment in designing entire engines, not just one or two engine components.
Old Feb 12, 2003 | 12:33 PM
RR98ITR's Avatar
...So they have a transient response dyno. So what?
Forgive me for being a stickler - but it doesn't say that precisely.
Scott, who is going to be more of a stickler this time....if there is a this time....
Old Feb 12, 2003 | 12:34 PM
Chris N's Avatar
"Cosworth Engineering has custom built 3 new transient dynos in Northhamptonshire England."
Ok, it doesn't say TR. My Bad.
Old Feb 13, 2003 | 07:25 AM
hitechex's Avatar
25 Year Member
Unless you build race cars and engines for a living then most of what is thrown around about transient response is just words. To those very few who do this type of stuff for a living, undersatnd what transient response means. How to break it down into terms that would mean something to the average guy. Probably can't be explained to his satifaction. Since I deal with these type of things on a daily basis. I understand what it all means, and how we quantify it with how we test our engines and exhaust systems. This is not just some simple math equation, this is cutting edge dynamics, which is over most peoples heads. I posted this in reply to Scott's attack on what he calls my koolaide! Snake oil or whatever.
There are simply to many variables that happen inside a race engine to attach some kind of label to. Phenomenons occur that have no explanation i.e. transient response or transient. The main purpose of the post was to enlighten all of you to the fact that what I talk about isn't just hype. It is real world dynamics. The fact that Cosworth has even come out and said they have built special transient dyno's is giving away a lot of info. Just mentioning the transient dyno will bring a whole new approach to how they desing and build their F1 engines and how others will follow. And eventually it trickels down to you the consumer who gets the benefits of it all.
Old Feb 13, 2003 | 07:36 AM
Are you telling the truth, this time?
...just like OJ.
Old Feb 13, 2003 | 07:56 AM
Chris N's Avatar
This is a piece of machinery, i.e., Mechanical Engineering, math, physics, etc.
There is no 'phenomena' involved in mixing air and fuel, compressing and combusting. It is all easily explanable.
If it is in fact cutting edge dynamics, then it will have to be mathematically accounted for, or else it is nothing, correct?
Dynamics is explainable. This is not, you said so yourself.
Please explain.
Old Feb 13, 2003 | 08:09 AM
RR98ITR's Avatar
Just a bunch of words - saying very little. As usual.
Here John is holding himself up (againe) as an elite high priest of TR Mojo.
And here's Cosworth giving away the secrets of the few. Puhleeze.
We've covered just about every reasonable relevant idea in these recent threads, and I'm pretty tired of the subject. Several of us are working on putting finis to this subject to the satisfaction of the reasonable "average guy".
Everyone is moving past Hytech anyway. The cutting edge in header technology appears to be AN-R now. They've got fantastic ideas that are way outside the box. Top racers everywhere are turning to them now because at that level of competition every fraction of a second counts. They're agreed by most top racers to be the secret to victory. Many are secretly using these headers while running the stickers of obsolete manufacturers. I'm giving away secrets but soon everyone will know anyway, and they've always got radical new advancements waiting in the wings to keep their top racers on top anyway. Just thru the latest secret advancements in the fantastic technology they've shaved several seconds off of the worlds fastest racers times. Porsche, Cosworth, Renault, Honda....they've all got spies trying to figure out what's going on, but they can't because they're not smart enough. Even Hytech with all their resources and experience have been left in the dust scratching their *** and wondering how they got here.
Scott, who can't tell you anymore, because you wouldn't understand....
Old Feb 13, 2003 | 08:31 AM
Chris N's Avatar
I was thinking 'shrowded in mystery' when trying to describe what I was reading, all this undescribable/unmeasurable stuff.
I thought TR was a measurable engine characteristic, not religon-based.
Old Feb 13, 2003 | 08:54 AM
REDNECK TYPE-R's Avatar
THEN HOW ARE THEY MEASURING IT OR LOOKING FOR IT????
Old Feb 13, 2003 | 09:08 AM
CHEETAH's Avatar
*sigh*
sounds like a cheap shot at John to me ... keep trying
maybe one days I'll post a dyno chart of one of my motors using his header vs. the *other* guys ... prolly shut you up once and for all LOL
BTW, bring the AN-R one anytime you want, we'll put a wager on it too
Greg
