Which Torque sequence help.
Old Jun 8, 2007 | 01:33 AM
realis9's Avatar
Default Which Torque sequence help.
O.k I did some searching and i found two. Which one is the correct way.
tightening
73159
842610
or
93157
862410
loosening
261084
35 971
Old Jun 8, 2007 | 04:54 AM
migs's Avatar
Default Re: Which Torque sequence help. (realis9)
I dont even know what thats referring to.
Old Jun 8, 2007 | 05:08 AM
RTW DC2R's Avatar
thats the head torque sequence. the first one is definitely NOT right. the second is close but not sure about 7,8,9,10.
i think loosening is just the opposite of tightening. so once you figure out the correct tightening sequence, you will be fine. make sure you only tighten/loosen in small increments.
helms is your friend.
Old Jun 8, 2007 | 05:23 AM
RPRacing's Avatar
This is what i use.
93157
862410
loosening
261084
35 971
Modified by RPRacing at 10:10 AM 6/8/2007
Old Jun 8, 2007 | 05:26 AM
RTW DC2R's Avatar
Default Re: Which Torque sequence help. (RPRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RPRacing &raquo;</TD></TR><TR><TD CLASS="quote">This is what i use.
73159
842610
loosening
261084
35 971</TD></TR></TABLE>
you are "supposed" to use a crisscross pattern when tightening as per helms...
however it probably doesnt really matter as long as you spread it out evenly across the head and go in small increments.
Old Jun 8, 2007 | 06:09 AM
RPRacing's Avatar
oh ****. copied the wrong diagram.
Old Jun 8, 2007 | 07:36 AM
walker111's Avatar
Default Re: (RPRacing)
Loosening I use an impact and just have at it, tightening, i go by what the helms says.
Old Jun 8, 2007 | 09:09 AM
itr1244's Avatar
Default Re: (walker111)
i was like wtf is this guy talking about? lol
Old Jun 8, 2007 | 10:48 AM
realis9's Avatar
Default Re: (itr1244)
dam i went with this for tightening
73159
842610
Did i mess up anything? Can i just loosen and re torque them again. The motor has not been turned over. I have brand arp head bolts and oem head gasket too.
So this is the right way?
93157
862410
Is this the correct way to loosen?
261084
35 971
Old Jun 8, 2007 | 11:12 AM
RTW DC2R's Avatar
as I said, if you do increments, it shouldnt be a problem. the whole point to torqueing the head down a certain way is to get a nice even flat seal and avoid warping the head. if the motor is step decked or o ringed you can have problems if you dont do this properly. if the motor is stock or close to stock you will probably be fine.
Old Jun 8, 2007 | 11:55 AM
realis9's Avatar
Default Re: (RTW DC2R)
thanks
Dangger
Sep 22, 2006 05:41 PM
Status Sean
Sep 2, 2004 08:54 AM
Hayasa15
May 27, 2003 05:29 AM
Anderson
May 9, 2002 06:54 AM
