Toda Cam Gear Lesson Please
I know there are different versions. I found a set that is about 3 years old and they have the 4 bolt design. Believe it or not these are 3 years old and never out of the box. Anyone know if there are any problems with these to watch for?
Re: Toda Cam Gear Lesson Please ('01ITR#950)
Are the old ones just heavy? Is that the difference? I hear Toda gears are heavier than most but I don't know if that's referring to the older model.
[Modified by SurferX, 7:40 PM 6/27/2002]
Re: Toda Cam Gear Lesson Please (Asahi)
i dont understand why people just dont use a brand other than toda if there is such a problem with the gears? i have been using my skunk2s for like almost 2 years w/o and probs
Re: Toda Cam Gear Lesson Please (BustaNutt-616)
just a matter of preference I guess.
people prefer to use gears that break and have to be continuously designed and are hard to learn to use? i wanna shake their hand!
Never heard a bad thing about Toda gears. Iwanted clarification between the gen1 and gen 2 gears. Skunks are an option too but if I can get these cheaper than skunks and they DON'T have problems what is the problem with that?
That's cool. So do you know of a problem? I think the timing marks changed but was looking for some confirmation.
Gen 1 Toda gears are the same as the Spoon gears.
Gen 2 Toda gears came with more accurate degree markings and made of aluminum to make it lighter.
Re: Toda Cam Gear Lesson Please (t)
1. They're similar, but not quite the same.
2. Yes, gen 2 are vernier scale. Very accurate once you learn how to read them.
some people prefer the toda quality. You realize that your beloved skunk2 gears are mis-degreed from the factory, right? No problem if you use a degree wheel when installing them though, right? No such problems with any generation of the toda gears.
New User
Re: Toda Cam Gear Lesson Please (sgT)
is it possible that the 2nd gen toda gears in position 0,0 are different from stock non-adjustable gears? if i install them in position 0,0 will i loose power?
Re: Toda Cam Gear Lesson Please (Black R)
..but you knew that, right?
Do you know your motor doesn't care if your cam gear reads 1 degree or 3 degree's if dyno tuning? If you pick up x hosepower at x degree, the motor has no way of knowing "I'm at 2 degree's but the cam gear says 2.5.....oh no"
Just a thought.
[Modified by CKDC2, 9:08 AM 6/28/2002]
Just a thought.
Re: Toda Cam Gear Lesson Please (CKDC2)
Just a thought.
Just a thought.
Location: Toronto, Canada currently residing in ATL, GA, USA
Wow Busta Nutt such animosity towards BlackR. Did he **** you off on some previous post or something.
wow, someone sure knows a lot about me eh? Take a look at my past thread history and see what I've installed.
nice. such a tough guy from behind a computer.
Buster.
Buster.
