timming issue
Old Apr 26, 2005 | 06:11 AM
ek4 coupe's Avatar
Default timming issue
ok this might not be the correct forum for the kind of question, but i know there are some guys in the type r forum who know there stuff. so im looking for help on timming my engine after my cam install. i have skunk2 stage one cams, intake manifold and valve train. everything is tdc and the valves are adjusted properly. im gonna triple check them tonight to just make sure. well when i start the car it idles alittle rough, then it spudders under load. so if i get it to run decent then it wont idle. i used a timing gun and everything seems to be right. its just not running properly. i tried playing with advancing the intake cam 2 degrees and retarding exhaust cam 2 degrees it wouldnt idle but it ran some what ok. im wondering could it maybe be a fuel issue, but i dont think it should because the cams arent that agressive. any info would be apperciated. thanks
Old Apr 26, 2005 | 08:15 AM
SecretAgent's Avatar
something is off a tooth. retime everything again.
Old Apr 26, 2005 | 12:49 PM
ek4 coupe's Avatar
Default Re: (SecretAgent)
will do. thanks
Old Apr 26, 2005 | 01:34 PM
Chubz's Avatar
Default Re: (ek4 coupe)
make sure the white mark on the crank pully lines up with the tdc mark on the lower timing belt and make sure that the 90 degree marks on the cam gears line up with each other, did you just eye up the gears in the up position? Also did you adjust the valves in the right firing order 1,3,4,2
Old Apr 27, 2005 | 05:41 AM
ek4 coupe's Avatar
Default Re: (Chubzilla)
yes i did adjust the valves they are good. i triple checked them. the mark on the crank pulley is off maybe a 1/8 of and inch. im thinking that is my problem. i didnt think it would affect it that much. i tried adjusting it by the distributor. but i dont think that did enough. thanks
Old Apr 28, 2005 | 01:37 PM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 coupe &raquo;</TD></TR><TR><TD CLASS="quote">yes i did adjust the valves they are good. i triple checked them. the mark on the crank pulley is off maybe a 1/8 of and inch. im thinking that is my problem. i didnt think it would affect it that much. i tried adjusting it by the distributor. but i dont think that did enough. thanks</TD></TR></TABLE>
my timing was off by an eighth of an inch, but it never did what yours is doing
d15 power
Oct 17, 2006 08:37 AM
bootlegtrader
Oct 25, 2005 05:30 PM
ek4 coupe
Apr 26, 2005 12:48 PM
Capt. Jimbo McSubipants
26
Mar 17, 2005 06:53 PM
sa21199
Mar 30, 2002 05:34 PM
