timing issue
Old Jan 4, 2009 | 02:42 PM
mystikal-vti's Avatar
Default timing issue
hi guys im having problems timing my teg r . since i put a set of skunk 2 cams in it .
when i time it using a timing light and get it to 16 degrees .and line it up to the middle line on the bottom pulley the dizzy is pushed right back as far as it goes . but if i time it to 16 degrees using the tdc line on the pulley the dizzy is right smack in the middle any idea's what could be wrong
Old Jan 4, 2009 | 07:05 PM
Shawn C's Avatar
In The Garage
Default Re: timing issue
are you jumping the diagnostic plug under the pass. side dash before you move the dizzy? (this puts it in base timing mode. otherwise, the ecu corrects)
JDMtype Eg6
Sep 3, 2008 05:14 AM
roterx7
13
Mar 13, 2006 06:36 AM
slowd16z6
Mar 13, 2004 02:20 PM
EKB18BPR3
Nov 30, 2003 10:36 AM
powerfulperformance
Oct 20, 2003 04:58 AM
