temp guage problem
Old Oct 12, 2003 | 08:46 AM
twuelfing's Avatar
Default temp guage problem
My temp guage needle swings the wrong way when my car is started.
When you put the ingntion in the on position it drops down to the left until it bottoms out.
It works intermittantly, however most of the time it is just buried to the left.
anyone else have this problem or possibly a solution to this problem.
Old Oct 12, 2003 | 09:10 AM
hYpE-R-29's Avatar
Default Re: temp guage problem (twuelfing)
got a pic of it???
Old Oct 12, 2003 | 09:29 AM
twuelfing's Avatar
well i could take one, but i dont think it would help at all.
just picture the needle moving the wrong way when the key is in the on position.
i will go shoot a short video and a picture maybe it will help.
Old Oct 12, 2003 | 09:42 AM
twuelfing's Avatar
Default Re: (twuelfing)
ok here is the video if it. not sure if it should be a picture or a url... here is both
http://www.magwerks.com/troy/temp.mpg
Old Oct 12, 2003 | 10:48 AM
B2FiNiTY's Avatar
So it doesn't work when the car is fully warmed up?
Old Oct 12, 2003 | 11:02 AM
twuelfing's Avatar
nope, it just says buried
i took it to the dealer when it was under warranty and they made it work, but that lasted about a month
I dont feel like having them fix it again and i have no problem taking the cluster out. I just wanted to get an idea what the problem may be before i start incase i need a new guage. I would rather order that before i get into it.
Old Oct 12, 2003 | 11:09 AM
EPGONZALEZ's Avatar
maybe the temp switch?
where are all the honda techs at?
Old Oct 12, 2003 | 11:19 AM
ZygSpeed's Avatar
Default Re: (EPGONZALEZ)
Sounds like something is shorting out and/or a bad ground.
I'd try checking the voltage at the sender, and then correlating that with what you find at the gauge/cluster.
Any other electrical problems or electrical installs recently?
Old Oct 12, 2003 | 11:26 AM
twuelfing's Avatar
no other problems.
no other electrical installs
started the helms trouble shooting and it passed the test for the guage. I am getting ready to do the test for the sending unit.
Modified by twuelfing at 9:01 PM 10/12/2003
Old Oct 12, 2003 | 12:02 PM
twuelfing's Avatar
OK just finished the checks for the guage and sending unit.
both seem to be OK
i am guessing its a loose wire in the cluster.
i guess this isnt a problem many other people have had.
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twuelfing &raquo;</TD></TR><TR><TD CLASS="quote">started the helms trouble shooting and it passed the test for the guage. I am getting ready to do the test for the sending unit.</TD></TR></TABLE>
Good thing you've got a Helms.
I was just looking through my 97 Electrical supplement ... good luck. Ed
Old Oct 12, 2003 | 02:06 PM
twuelfing's Avatar
well i pulled out the cluster (took about 4 minutes)
and turned the 3 screws on the back of the temp guage about 1/16 of a turn and now it works again
we will see how long this lasts.
thanks for the help though
Old Oct 12, 2003 | 02:42 PM
DOHC_VTEC786's Avatar
New User
does the car run cold for a while?? if so does the gauge only work when you let the car idle till full running temp?
if so then your thermostat is stuck open.... I had the same problem
Old Oct 12, 2003 | 03:47 PM
twuelfing's Avatar
no the guage would actually bury its self down on the cold side (look at the movie)
it doest run cold for a while it works perfectly except the guage. The guage would never come up out of the pinned cold position.
i cant explain it any other way, but the video shows you what was happening.
its fixed now. I just wanted to post what i did incase someone in the future had a similar problem. I see too many posts where the resolution is no where to be found becuase once the person figured it out they were done dealing with it.
Old Oct 24, 2003 | 08:11 AM
typer_801's Avatar
I've got the *exact* same problem. Mine started when I pulled my tranny the first time intermittenly and after I pulled it the second time it has been permantly pegged to the left.
Thanks!
lj420p
Feb 22, 2006 01:05 PM
JunkyardDog
Nov 28, 2005 11:02 AM
