Teins?
Old Sep 10, 2001 | 06:36 PM
IntegraT's Avatar
Default Teins?
Who out there has Teins, and how bad *** are they? Dropping my ITR is the first mod I'm going to do, and I want to make the right choice. If I had to by springs right now I would by Teins or Endless, but I would like feedback first, good and bad. So anything anyone knows about them and maybe a lttle insight on the different series:CS, NR, NA, HR, HA. It's a lot to absorb (get it) sorry. Thanks.
Old Sep 10, 2001 | 07:31 PM
Rob :190:'s Avatar
Default Re: Teins? (IntegraT)
Nosamk, the dude who sold me my R, installed Tein HAs on it. I absolutely love them. I mess with the stiffness all the time, they handle well. Although i can't really compare to stock. The height is great right now, a good combination of low height and streetability.
Old Sep 10, 2001 | 07:40 PM
AJ PwR's Avatar
Coil-over??
ZEAL B, B2 , B6 ,S6 or Super Function... depends your application. Qualitywise, ZEAL will be over Tein.
Tein is made out steel with welded on coil-over sleeve very easy to rust. Ride quality is good.
ZEAL is made out of chromoly steel, machined sleeve with the shock body. Comes with hard bushings upper mount.
Pricewise they are very close so that's what I can say Boss
Old Sep 10, 2001 | 07:50 PM
Benjamin Tang's Avatar
Default Re: Teins? (AJ PwR)
like he cares about rust!!! he lives in arizona!
buy my ha's so i can finance for new zeals please
Old Sep 10, 2001 | 07:57 PM
Cyrio's Avatar
Default Re: Teins? (Benjamin Tang)
Ben: Are you selling your HA's??
Old Sep 10, 2001 | 08:04 PM
Default Re: Teins? (Cyrio)
i would like to... those zeals hanging on the wall at a&j are calling to me.... dammit! i'm not going to blink this time!!!
AJ PwR's Avatar
Sure if you wanted to no problem!!!!
Old Sep 10, 2001 | 08:18 PM
IntegraT's Avatar
Is that the only advantage the Zeals have over the Teins (rusting, cause your right I'm not really woried about that), what about ride.
ah, the jdm devil calls... help?
Old Sep 11, 2001 | 01:18 PM
mafay2's Avatar
New User
I just install the TEIN NA on my car. It is not a real coilover, but they do allow you to set the height to 3 differences position. I set mine to the highest one, and it give around 1.5" of drop, which is perfect for me!!
It doesn't have any coilover sleeve, so rusting is not an issue at all. Also, even if you have the HA, all you have to do is to apply some anti-sieze to the sleeve during install, it will take care of all rusting problem. So if the shop install the HA for you know what they are doing, there shouldn't be any rust problem!! I have a few friends with HA and none of them have any rusting problem. They all love the ride of it and said won't go for any other coilover for street application!!
Oh, the reason I didn't buy the HA? It is because I am short on cash and a got a great great deal on the NA (free S'Tech spring and LCA ) Also, I used to have the Koni and GC set up, and I NEVER adjust the height after I have it set, so why bother with coilover??
Comparison between NA and Koni/GC? The TEIN NA give much more comfortable ride quality, but it did get very stiff when I corner due to the progressive spring rate. I set it to softest for my highway trip back home. But I tried out the stiffest setting right after I install it, it is still very acceptable for street use!! I LOVE IT!! Money well spend!!
Old Sep 11, 2001 | 02:29 PM
hybrid_eg's Avatar
i installed my HA's recently too.. dont have to worry about rust in socal.. but the only problem that i faced so far is that the locking nut on the top of the shock that goes through the adjusting ****.. have come loose.. first the front two and last night my rear right. I tightened them down some more and they seem to work fine.. when the locking nut was loose there was too much play and they were extremely loud on every bump.. did anyone run into these probs?
Old Sep 12, 2001 | 05:16 AM
bhcvc's Avatar
What's your price range? That will quickly reduce your options as most of the Zeals and Teins are at or above $2000 (Zeal B6/S6, Super Function; Tein RA, RE, N1, RS). Also, not all Teins have rust issues, only the HA's. The other Tein's actually have aluminum bodies. The Zeal S6 and I think Super Function also use aluminum. It's the B-series that's chromoly. Since you're not worried about rust, Tein HA's can be had for about $1200-$1250 w/o upper mounts, so that's a good deal. Zeal B2's (HA's competition) comes with upper mounts standard, so that's factored into the price so it's higher. Dunno if you want metal mounts or not. I got a set of A'pex N1's (99-spec) and I like them a lot. Tho, I found a place carrying JIC's that I wanna check out...mmm, more toys...this is bad. Good thing I'm not close enough to BC to be so temped by AJ...that'd be soooo bad for my bank account.
Old Sep 12, 2001 | 05:23 AM
S13Koop's Avatar
Default Re: Teins? (bhcvc)
I've got the HA's, love em! Whats this rust everyone is talking about???
Old Sep 12, 2001 | 05:26 AM
bhcvc's Avatar
Default Re: Teins? (winglessR)
The threaded portion of the HA's is made of steel and have had some pretty bad rust probs in certain areas (mostly cold areas where they salt the roads or near ocean/beach areas). They're also a lil heavier than some of the other coilovers cuz of their steel construction.
Old Sep 12, 2001 | 08:28 AM
Nick248's Avatar
I live in New Jersey and I have Tein HA's. The roads are bad, cold and salty and I had absolutely no problems with rust (no signs of it either). Here is the trick, alittle antiseize on the thread only where it is needed. Then spray WD-40 on the whole coilover every month or so. This keeps the moisture away. I absolutely love them. The softest setting is softer than stock and the harder setting is like driving on cement shocks. They are great.
My only concern is that they're probably heavier than the stock assembly which means alittle more unsprung weight. (haven't confirmed that yet). I haven't seen any degradation of performance, actually the car is significantly well-planted on the track.
I play with the dampening all the time. Somedays I want smoothe rides, other days I want stiff. After driving on them for awhile, you can tell a difference between each click. I use them all!
-Nick248
Old Sep 12, 2001 | 09:31 AM
JUNpoweredITR's Avatar
New User
I got them and I like them a lot. Albeit that I have only done 7 laps on them.
Peep it here...
http://www.clubvtec.com/integra/f223.html
Peace...
Old Sep 12, 2001 | 12:50 PM
nomorecrx's Avatar
New User
well get ra's then...they are mono-tube aluminum. the ride is a bit stiff though, but i could take turns like no other...heh.
projekt90ef
Suspension & Brakes
Aug 25, 2010 09:50 AM
kcari
Suspension & Brakes
11
Sep 13, 2007 07:44 AM
numbnuts22715
Suspension & Brakes
Dec 28, 2005 12:52 PM
wreckedagain
Nov 22, 2004 11:12 AM
00MRSi
Apr 5, 2002 03:47 PM
