tein flex??
Old Apr 28, 2007 | 12:10 PM
CDN Yellow ITR's Avatar
Default tein flex??
whats up guys/gals
i just got my tein flex installed last week n i just started playing around with the settings last night, but the thing that confuses me most is that i can turn the *** like 25 times and lastly is all the way to the right stiff, just wanna make sure..
ne info would be great
-tony
Old Apr 28, 2007 | 01:00 PM
98 ITR's Avatar
Yes, all the way to the right is full stiff. You will definitely notice when they're on full stiff.
Old Apr 28, 2007 | 01:09 PM
cxSHOE's Avatar
Default Re: tein flex?? (CDN Yellow ITR)
not sure if you got these with the edfc system. but if you did you need to switch out the gold inserts from the bottom of the adjusting valves. if you read the instructions on the edfc system there are two valve inserts gold and black. if i remember correctly the gold is to be used with the edfc, and the black if your not using the edfc.
basically the valves will turn a different amount depending on which valve insert you have inside.
no edfc system you want to make sure you have black valve inserts and not gold
Old Apr 28, 2007 | 01:26 PM
azn_ignite's Avatar
just remember lefty loosey righty tighty
Old Apr 28, 2007 | 02:36 PM
waddy41's Avatar
Default Re: (azn_ignite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azn_ignite &raquo;</TD></TR><TR><TD CLASS="quote">just remember lefty loosey righty tighty </TD></TR></TABLE>
thx captain obvious!
Old Apr 28, 2007 | 03:24 PM
jetydosa's Avatar
25 Year Member
Default Re: (waddy41)
My old HAs were "16 way" adjustable but had about 20-21 clicks
Old Apr 28, 2007 | 04:52 PM
s800's Avatar
How do ya like the Flex's?
Old Apr 29, 2007 | 12:22 AM
the flex are great for everyday driving, and handling is inproved
Old May 1, 2007 | 04:28 AM
Bart-EK's Avatar
AFAIK the gold/black inserts have little to do with how much the valving is adjusted 'per click'...
The gold ones needed for the motors are actually smaller (less tall) than the black ones, so I guess the 'alan key' which is the motor goes deeper into the shock than then manual counterpart (which you take off)...
But hte question was about how many clicks he can turn the things and yes, you can soften it up way too much (way more than the 16 clicks advertized) but I never even dared drive it like that... who knows what gets f-ed up because of it...
besides, 12F14R is soft enough for even my gf, so no need to go softer... DD for me is currently at 3F5R (trying different settings right now, to see what makes the car turn better)
For street driving (here in my neck of the woods in Europe) I'll most likely go back to 4F7R or something... I'm currently loosing grip in some bumpy corners right now
bootlegcivic
Nov 29, 2007 09:22 AM
asmallsol
Apr 29, 2003 09:23 PM
