Tech Request - My head needs help!
Old Jan 26, 2004 | 12:14 PM
strepto's Avatar
Default Tech Request - My head needs help!
Hi!
On my head there are to 10mm hex nuts - I believe they are called "allen"? that covers the rockershafts. There are two on the right side - and one of the left side. You need a hex socket - like a "brick" for lack of a better explanation.
They wont move. I mean - I have tried everything - and they just wont move.
I need to remove my valvesprings, retainers and valves - and from what I understand - I need to remove the rocker arms before I can do that.
Is there anything in particulor I should be aware of? Can I remove the valves without removing the rocker arms?
Thanks guys!
From the illustration you can see the parts marked with "1" - the bolts I am unable to remove.
Old Jan 26, 2004 | 12:39 PM
ECKOTYPER's Avatar
find the allen wrench that fits the plug, and put it there, then geta big *** pipe like 3 feet long, put it over it, leverage is the key to help breaking buts loose, we did a itr head, and this method worked perfect
Old Jan 26, 2004 | 12:42 PM
baonest's Avatar
Default Re: (ECKOTYPER)
heat it up with a torch, its probably frozen, you dont want to strip it.
Old Jan 26, 2004 | 12:47 PM
Willard's Avatar
Default Re: Tech Request - My head needs help! (strepto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strepto &raquo;</TD></TR><TR><TD CLASS="quote">I need to remove my valvesprings, retainers and valves - and from what I understand - I need to remove the rocker arms before I can do that.</TD></TR></TABLE>
You can remove the springs, retainers and valves with the rockers in place.
Is the head on or off of the motor?
Old Jan 26, 2004 | 12:48 PM
baonest's Avatar
Default Re: Tech Request - My head needs help! (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">
Is the head on or off of the motor?</TD></TR></TABLE> oh yah, you can.
Old Jan 26, 2004 | 01:04 PM
strepto's Avatar
Default Re: Tech Request - My head needs help! (baonest)
The head now resides on my desk for further studie I have the entire assembly - with a new set of P73 valves, rocker arms, shafts and .. well. .yeah.. thats about it. Putting in an order for a M24X valvetrain and cams now.
Old Jan 26, 2004 | 01:16 PM
Batoutahell's Avatar
Buy a hex socket and use your ratchet to break them free.
Old Jan 26, 2004 | 01:17 PM
strepto's Avatar
Default Re: Tech Request - My head needs help! (Batoutahell)
Already tried that - didnt help.
How do I remove the valvesprings and retainers?
Old Jan 26, 2004 | 01:23 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strepto &raquo;</TD></TR><TR><TD CLASS="quote">Already tried that - didnt help.
How do I remove the valvesprings and retainers?</TD></TR></TABLE>
Buy a Helms. http://www.helminc.com
Old Jan 26, 2004 | 01:27 PM
strepto's Avatar
Default Re: Tech Request - My head needs help! (nfn15037)
Got one. Says how to remove the top, the engine, the bla and the bleh. But doesnt go into detail about the head.
Old Jan 27, 2004 | 07:30 AM
strepto's Avatar
Okey, I got the bolts out.
i need a tool to compress the valvesprings in order for the retainer to loosen, right? Ive look a few places, but I cant find anything that fits in the little space you have in the engine.. Got any ideas?
Old Jan 27, 2004 | 08:06 AM
Pondus's Avatar
Well if you dig up your Helms it's shown on page 6-69 how to remove the valvesprings and retainers and what tool you need.
Old Jan 27, 2004 | 08:34 AM
strepto's Avatar
Default Re: Tech Request - My head needs help! (99ITR#3715)
Im sorry, no helms. Its the shop manual from honda. Still need to know what valvespring compressor to get..
Old Jan 27, 2004 | 08:37 AM
MattD@Stoptech's Avatar
https://honda-tech.com/zerosearch
enter "valve compressor"
either check "recent" or "archived" and let the results flow in...
HTH
nfn15037's Avatar
Thats what the helms is, they are the publishing company. If the head is off the car you can remove the valves and springs etc by using a socket roughly the size of the retainer and giving it a good smack, it will make the keepers pop out. You will need a compressor to to re-install however.
Old Jan 27, 2004 | 08:58 AM
IN VTEC's Avatar
Everything down to the valves can come out without removing the rockers.
If you really do need to remove them (say if you're gonna tank the head), get a 10mm allen head socket. Stick it on a ratchet and smack the ratchet with a hammer.
Old Jan 27, 2004 | 12:20 PM
strepto's Avatar
Default Re: Tech Request - My head needs help! (IN VTEC)
Rockers are out.. now remains the valvesprings.. this is a nightmare without the proper tools..
Old Jan 27, 2004 | 01:49 PM
sander's Avatar
2.7(p/t)
To remove/install valvesprings you need a special tool
http://buy1.snapon.com/catalog...talog
I have this one, and its very nice, but expensive as is all snap on tools. You can probably find a cheaper one that does the same thing if you look around. Its also nice to have a telescoping little magnet to get the keepers (little half circle clips that hold the retainer in) also.
-sander
Old Jan 27, 2004 | 05:08 PM
SC94DB8's Avatar
Default Re: Tech Request - My head needs help! (sander)
Here is a link to a spring compressor just like the Snap-On one, but cheaper. Even comes in the same red case. Their website says they are on backorder for 8-12 days though.
http://www.northerntool.com/we...yId=0
Old Jan 28, 2004 | 10:14 AM
nfn15037's Avatar
Default Re: Tech Request - My head needs help! (SC94DB8)
Like i said, you dont need any tools to disassemble the head. You will, however, need the spring compressor to reassemble.
Old Jan 28, 2004 | 12:42 PM
Racebrewer's Avatar
I've taken the valves out using the socket and hammer method. Very fast and efficient. Sometimes the valve keepers fly off in different directions. We used a shop rag placed over the valve retainer after the first keeper took off.
If you have a friend with real strong fingers he might be able to assemble by hand, if the valve is supported from below(?)
The Snap-On or similar tool is supposed to work on virtually all DOHC heads so you might be able to borrow something similar from another make. It may also be possible to make a knock-off of the tool fairly quickly if you know somebody in a machine shop.
John
invisible
Feb 7, 2007 12:18 PM
LSEGHATCH
Nov 15, 2006 12:13 PM
haggard hatch
Aug 5, 2005 06:15 PM
darrinbrewer
Feb 9, 2003 11:03 AM
B_CRUZ!
Jan 10, 2002 10:49 PM
