Stroker kit for B18c5
Old Oct 5, 2004 | 09:34 AM
type_r_jon's Avatar
Default Stroker kit for B18c5
Anyone stroke their Typey? I'm also considering forced induction. However the sroker kit is about a 1000 bucks less compared to others (roughly). I had no luck with a search on stroking a C5 so I thought I would ask if anyone has done it and if its worth it ? ? ?
Old Oct 5, 2004 | 10:14 AM
scooter's Avatar
Default Re: Stroker kit for B18c5 (type_r_jon)
instead of trying to stroke the C5 just go buy a LS or B20 block and balance the crank and have it sleeved and bored to 84.5mm. Unless you just want to retain the C5.
scott
Old Oct 5, 2004 | 10:31 AM
Bradstard's Avatar
Default Re: Stroker kit for B18c5 (scooter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scooter &raquo;</TD></TR><TR><TD CLASS="quote">instead of trying to stroke the C5 just go buy a LS or B20 block and balance the crank and have it sleeved and bored to 84.5mm. Unless you just want to retain the C5.
scott</TD></TR></TABLE>
why not sleeve your C5?
Old Oct 5, 2004 | 10:50 AM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_r_jon &raquo;</TD></TR><TR><TD CLASS="quote">Anyone stroke their Typey? I'm also considering forced induction. However the sroker kit is about a 1000 bucks less compared to others (roughly). I had no luck with a search on stroking a C5 so I thought I would ask if anyone has done it and if its worth it ? ? ? </TD></TR></TABLE>
You'll get WAAAAAAY more power with FI than stroking.
If power increase is what you are after ----&gt; Forced induction
Old Oct 5, 2004 | 12:16 PM
BoostR41's Avatar
don't do that cause those motors are not meant to rev like the C5 block. no oil squirters and such.
just get the block sleeved, bore it to 83mm(so you have some wall still if something would happen and you would have to get it re bored) and turbo it.
Old Oct 6, 2004 | 05:32 AM
type_r_jon's Avatar
Default Re: Stroker kit for B18c5 (BoostR41)
I already have C5 so lets work with that.
so do both maybe? LOL No one on this board has stroked their 1.8 VTEC to a 2.0 ? ? ? I find that hard to believe. I think I am going to turbo but I imagine if I do both and run 7 PSI I'll prolly have a 400 HP engine (depending on things). That would be insane. I imagine running that much hp I'd have to change other things that didn't come with the turbo kit/Stoker kit.
N E WAYS someone give me the real stats on just stroken to a 2.0 R-VTEC with I/H/E. That would be sweet. Eagle & many of these other companies r saying like an extra 100 crank hp. I dun believe it.
thanks for the advice guys.
O one more thing I'm pretty new on this and like every other post I read people spell VTEC like "vtech" WTF
Modified by type_r_jon at 8:42 AM 10/7/2004
Old Oct 6, 2004 | 05:45 AM
Bradstard's Avatar
Oil squirters are used to help cool the cast pistons. If you are running forged pistons you won't need them. I am currently waiting to get my B18C5 block back...85mm. If you are going to sleeve it, go all out.
rdssk8rcs1
Mar 30, 2009 09:35 AM
raidacaipo
10
Oct 7, 2008 12:46 PM
iloveb16
Aug 6, 2007 10:05 AM
Da1spaz247
Oct 1, 2005 08:27 PM
untitled
May 14, 2003 07:51 AM
