Stepper pulley and CEL
I know this is a FI question, but it is ITR specific. I just had a Motorvations stepper pulley installed for the jrsc on my 98 ITR. About a day later I got a CEL. Before I could get the car in to get it checked out the CEL went away. I never noticed any difference in the way the car ran, but I didn't push it too hard while the CEL was on. Anyone have an idea as to what caused this? should I be worried?
Re: Stepper pulley and CEL (fredtoast)
What else did you get to help support the extra boost from Jim's Pulley?
Hondata? BTC? 440cc? If you just slapped on the pulley with out a standalone or no bandaid’s I'd expect major detonation problems. What code is the cell giving you?
[Modified by GSRAW, 11:06 PM 2/25/2003]
Re: Stepper pulley and CEL (GSRAW)
[QUOTE]What else did you get to help support the extra boost from Jim's Pulley?
I have MAP controller, high pressure 255 l/hr fuel pump, and BTC set at 10 clicks (I understand that to mean my timing will be retarded one degree for each pound of boost). It was set at 6 clicks when I was running 5-6 psi, and I never had any detonation problems.
I've never had a CEL before. Is there someway I can get the code without taking it in to the shop? Now that the CEL is gone, can I still find out what tripped it?
as long as the ecu was not reset, the CEL code will still be stored in the ecu. go to c-speedracing.com to find out how to check the code. good luck
Tyconway
09-29-2008 10:03 PM
