SRS Light Problem
Old Dec 17, 2009 | 10:57 AM
BlueIntegraBoy's Avatar
Default SRS Light Problem
I'm leaving in a week and a half for school (4 months at a time) and I would really like to figure out this SRS light problem.
My problem started about 3 weeks ago. The light turned on when I started the car. I reset the light and it never came on until two weeks later. I reset it again and it came on a day later. It's not like I reset it and it comes back on the next time I start the car.
Any ideas or suggestions? Thanks.
Old Dec 17, 2009 | 11:47 AM
mugenr#1011's Avatar
Default Re: SRS Light Problem
airbag sensor maybe? do you have the stock steering wheel on still?
Old Dec 17, 2009 | 12:39 PM
I had a JDM SRS wheel for over a year without problems.
Old Dec 17, 2009 | 02:07 PM
Dr. DC2's Avatar
i've heard of this being the problem before... dont know for sure why but ive heard that the japanese airbag will not deploy and the srs light wont recognize the wheel having an airbag. i know that doesnt explain much but just thought id let you know that ive heard of it happening before
Old Dec 17, 2009 | 02:21 PM
I just reset it again. We'll see how long it will last. I ran the wheel over a year without any SRS lights. Age is getting to the R...
Old Dec 17, 2009 | 02:25 PM
sawjai526's Avatar
you can bring it to dealership, should be free or charge to service the srs lights , due to malfunction of the system. I had my parent 2000 accord service in 2008 free of charge. should be cover under life time warranty. just like the seat belt life time warranty.
goodluck
Old Dec 17, 2009 | 02:42 PM
Big Phat R's Avatar
Put a piece of black electrical tape over the light
Problem solved
Old Dec 17, 2009 | 05:55 PM
goodluck
Not with the JDM wheel.
Problem solved
Would be cleaner to just remove the bulb.
Old Dec 18, 2009 | 12:44 PM
USDMCIVICHATCH's Avatar
I have had this happen before. More then likely the connection on the driver side airbag isn't making good contact. Did you clear it with a obd2 scan tool? I have one and it tells me where the problem is. It really can only be 3 things one of the two airbags or the airbag module behind the center console.
Old Dec 19, 2009 | 01:13 PM
tipe R's Avatar
i would find out what the fault is before clearing it. you might as well find out what the fault is, then you can decide if it's important or not. if the steering wheel wasn't compatible it would cause the light to come on immediately, sounds like an intermittent fault. poss. the module or a loose contact somewhere
Old Jan 14, 2010 | 04:39 PM
yank4life's Avatar
New User
I have a similar issue with my 2003 Accord. Sometimes the light stays on when I start my car and sometimes it doesn't.
Will a dealership cover this since it is 7 years old and over 107K miles on it?
alexcls02
Acura TL, RL & ZDX
Nov 8, 2015 09:01 AM
kcoons
Honda CR-V & Element
Feb 12, 2014 03:27 AM
pennies_hatchie
Oct 20, 2005 07:14 PM
itr-j
Nov 27, 2003 06:21 PM
