Squeaky Clutch...
Old 10-21-2001, 03:53 PM
Tommy_Gunns's Avatar
Default Squeaky Clutch...
Just noticed that my clutch squeaks when I press it down. Anybody else have this symptom? I'm gonna spray slick 50 lubricant on all of the linkages of the clutch pedal...hopefully that will fix it.
Old 10-21-2001, 04:11 PM
New User
PrjctDC2-R's Avatar
Default Re: Squeaky Clutch... (Tommy_Gunns)
Yup I had that problem.... Grinding Clutch Pivot....just lube it up
Old 10-21-2001, 04:29 PM
JohnnyBoy's Avatar
Default Re: Squeaky Clutch... (PrjctDC2-R)
It is probably in the clutch fork area. I had it there too. I sprayed some lube under the rubber boot at the front of the engine.
Old 10-21-2001, 06:56 PM
Default Re: Squeaky Clutch... (JohnnyBoy)
Rubber boot at the front of the engine? Is that underneath the tranny housing?
I think we got sibbling ITR's or at least distant cousins...
Old 10-21-2001, 08:18 PM
PiYoImuT's Avatar
Mine does the same thing.. so are we distant cousins too?
Old 10-21-2001, 08:21 PM
Rob :190:'s Avatar
Default Re: Squeaky Clutch... (PiYoImuT)
mine clicks on occasion, does that make us like penpals or something?
Old 10-21-2001, 11:17 PM
New User
Type R 702's Avatar
Default Re: Squeaky Clutch... (Rob Maybach)
my car did that too acura kept lubing it up till the pressure plate snapped and i got a whole new clutch, flywheel, throwout bearing, etc and finally no more squeaking.
Old 10-22-2001, 03:07 AM
Aoi-Zip's Avatar
Default Re: Squeaky Clutch... (Type R 702)
i've got that problem too...
so lubing it up should do the trick... right?
Old 10-22-2001, 02:38 PM
BLITZ's Avatar
Default Re: Squeaky Clutch... (DC2-B18C5)
If you have less than 12,000 miles & less than a year with your car you can take it to the dealer & they will fix it for free. Thats what I did.
Old 10-22-2001, 04:10 PM
JohnnyBoy's Avatar
Default Re: Squeaky Clutch... (BLITZ)
I think he was referring to our cars number plates....
I think it was where the slave cylinder is...but in behind it
[Modified by JohnnyBoy, 5:11 PM 10/22/2001]
Gabbie2598
05-05-2019 03:50 PM
Eddieman201
12-13-2008 02:31 PM
hondaracing1
06-22-2005 11:15 AM
t0ekn3e
19
04-17-2005 07:46 PM
tianporn
11-05-2004 12:18 PM
Quick Reply: Squeaky Clutch...
