Side moldings?
Side moldings?
I know all the integras except for ITR had side moldings, and i was wondering wut would an rs/ls/gs/gsr look like with the molding taken off? will it look like the ITR or will it have a lump on where the molding use to be.
I just kinda think my CW rs would look alot better without the side moldings
Re: Side moldings? (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 »</TD></TR><TR><TD CLASS="quote">not all integras came with side moldings, and resize!!!!!!! 97spec yo</TD></TR></TABLE>
are u sure? because every integra on the street i see that are not Type R, has black side moldings or moldings that've been painted over like mine.
And can someone answer my question on wut will my teg look like if i remove the side moldings
Re: Side moldings? (hubjub)
it will look like ****... there are clips that hold your side moldings on... you need to get some body work done to make yours look like an RRRRRRRRRRR
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hubjub »</TD></TR><TR><TD CLASS="quote">And can someone answer my question on wut will my teg look like if i remove the side moldings</TD></TR></TABLE>
Um, have you ever seen the side of a Type R? That's what it would look like.
Once you filled in the holes left by removing the side moulding, that is.
Re: Side moldings? (misfit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit »</TD></TR><TR><TD CLASS="quote">it will look like ****... there are clips that hold your side moldings on... you need to get some body work done to make yours look like an RRRRRRRRRRR </TD></TR></TABLE>
Look like ****? can u provided me a pic or 2 of wut integras look like with those sides removed?
So if i remove them it'll leave how many holes? and wut could i use to fill in the holes to make the doors look sexy like the R.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hubjub »</TD></TR><TR><TD CLASS="quote">So if i remove them it'll leave how many holes? and wut could i use to fill in the holes to make the doors look sexy like the R.</TD></TR></TABLE>
Ten holes maybe? Dunno.
Ghetto fill = Bondo and repaint.
Choice fill = body shop and repaint (they'll probably use Bondo as well, but they'll do a better job).
Too much trouble and not worth it at all.
It leaves like 10-15 holes IIRC, you need to weld in the holes then file, sand, smooth, paint the side of the car to get it to look right. I know b/c I just painted my car. and removed those moldings:
Of what it will look like done correctly...that car was originally a stock tafetta LS, now it's CW & black....
Modified by JoesTypeS at 11:55 PM 9/18/2004
Re: (JoesTypeS)
once u take off the side moldings u will have holes. u need bondo and u gonna have to sand it down. than get a new paint job . that will look like a type r.
Re: (Bootleg R)
wut is the price range in us or cdn (prefer cdn) $$ of the cost for sanding down and bondoing the holes? dude with the ls how much did it cost u?
Re: (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy »</TD></TR><TR><TD CLASS="quote">You could get ITR doors and then just do the back panel... </TD></TR></TABLE>
yes you could, then just blend the fenders to the door
1 Post
Re: (Bootleg R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bootleg R »</TD></TR><TR><TD CLASS="quote">once u take off the side moldings u will have holes. u need bondo and u gonna have to sand it down. than get a new paint job . that will look like a type r.</TD></TR></TABLE>
wouldn't welding the holes shut be a better option than bondo?
Re: (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">Its funny, he asks how it would look without sidemouldings. Hmmmm, maybe just maybe you could find one of the millions of pics of a type R...</TD></TR></TABLE>
it's even funnier how you don't understand his question! He was asking if other integra models ie. LS and GSR's look the same after having thier moldings shaved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PMP_C_TEG »</TD></TR><TR><TD CLASS="quote">
it's even funnier how you don't understand his question! </TD></TR></TABLE>
Idiot
Read again:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hubjub »</TD></TR><TR><TD CLASS="quote"> i was wondering wut would an rs/ls/gs/gsr look like with the molding taken off? </TD></TR></TABLE>
No, you actually did ask what I said. Its the same damn thing and tons of integras have had their mouldings shaved, this isnt Type R related at all, its LS GSR RS whatever and its moreover Appearance/cosmetic related. Searching in there would have answered your question immediately.
Idiot
Read again:
Re: (sim shadeee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sim shadeee »</TD></TR><TR><TD CLASS="quote">
wouldn't welding the holes shut be a better option than bondo?</TD></TR></TABLE>
Welding would be the BEST option. Bondo will expand and contract with weather change. If you just shove bondo in there, after time you'll be able to see little sqaures pop up under your paint where the clips used to be. The forces that are put on your door from opening and closing it are enough to pop the Bondo out of the holes.
Re: (ITR 98 1162)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 »</TD></TR><TR><TD CLASS="quote">Welding would be the BEST option. Bondo will expand and contract with weather change. If you just shove bondo in there, after time you'll be able to see little sqaures pop up under your paint where the clips used to be. The forces that are put on your door from opening and closing it are enough to pop the Bondo out of the holes.</TD></TR></TABLE>
How much would it cost to weld the 20 holes on both side?
Re: (hubjub)
How much would it cost to weld the 20 holes on both side?</TD></TR></TABLE>
dude, you're asking questions that are easily answered by calling a local bodyshop that you PREFER to take your car to. to some people, a $500 job is half-assed and to some people that's great.
NOW GET THE GODDAMN PHONE BOOK.
Re: (nightrider)
i hav seen a nice *** non type r with cleanly shaved side mouldings ...
the key of course is 1 of 2 things
either
MONEY
patiences,hardwork, and TIME! (im ghetto fablolous so i would go this way... and while i do this i would **** up reapeatedly then finalyl do it right and be able to do this anytime i wanted for another sucker who is willin to put up that cash for doin it )
either
MONEY
