shift knob....
Old Jul 5, 2001 | 11:58 AM
01r's Avatar
01r
New User
Default shift ****....
this is pretty stupid but do oyu just unscrew the nut underneath the **** to get it off. im pretty sure but just wanna double, check. im putting in a red stiched shift boot...thanks to mike at ips racing.
Old Jul 5, 2001 | 12:15 PM
01r's Avatar
01r
New User
Default Re: shift ****.... (01r)
come on 14 views and not one answer???
Old Jul 5, 2001 | 12:17 PM
Che Guevara's Avatar
This may be obvious, but you are going to have to take the whole centre console off to change the boot I think...
As for the ****...I have a momo one, and you have to use an allen key to loosen little bolts first....then it just twists off..what **** are you using?
Old Jul 5, 2001 | 12:26 PM
Mike K's Avatar
Default Re: shift ****.... (99r)
Put some sack into it!
Twist it off. It comes off.
Then take a wrench and unod the nut.
Yank the console, and get your trusty Snap-On ratcheting screwdriver and change the boot.
Done!
figment's Avatar
New User
OK, OK! yes the nut on the bottom is losened to unscrew the stock R shifter ****.
-figment, who should know because his was ripped off.
Old Jul 5, 2001 | 12:30 PM
01r's Avatar
01r
New User
Default Re: shift ****.... (figment)
wait a minute now im getting different answers!!! mike said to just twist it off and then undo the ****?
figment says to unscrew the nut and then twist the **** off???
sorry but i have an oem ****
Old Jul 5, 2001 | 12:37 PM
01r's Avatar
01r
New User
thanks figment!!
Old Jul 5, 2001 | 12:40 PM
nsxtasy's Avatar
H-T Order of Merit
Do you want people who don't know the answer to reply?
Keep in mind - you titled the topic "shift ****" and not "how do I remove shift ****". So anyone might view it thinking that you were selling one or showing a new one or whatever, but couldn't tell from the topic name what you were really asking about.
Old Jul 5, 2001 | 02:18 PM
figment's Avatar
New User
Default Re: shift ****.... (nsxtasy)
I IM'd him with the specifics. (I must give credit to Willard though. He told me about this after the DEALER could not figure it out )
[Modified by figment, 11:19 PM 7/5/2001]
Old Jul 5, 2001 | 03:23 PM
Jason's Avatar
This is how you do it...I just installed a JDM shift boot a couple of weeks ago.
to get the **** off, just twist it off...the bolt is only there so you can line up the H pattern on top of the ****.
You have to take off the center console, two screws under the ashtry, two screws on either side under the dash for the center console. Pop off the plastic piece inside where you put down the ebrake handle and remove the two screws there. Two more screws on each side (you have to move both seats forward to get to them) of the console. Slide the back portion of the console off...done w/ that...
If you removed all of the screws from under the ashtray and under the dash portion, the front portion of the console should slide out...
Unscrew four screws holding the shift boot in and replace...It's that easy...
Hope this helps
Jason
Bright13
Honda S2000
Oct 30, 2011 03:10 PM
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
tnewhallSi
Mar 31, 2006 11:44 PM
pre1udekid
Jul 12, 2004 03:49 PM
sexyaccord
Mar 29, 2002 10:39 AM
