Rough Idle?
Old Jun 6, 2007 | 01:33 PM
AlienKrOZ's Avatar
Default Rough Idle?
my idle on my 97R is jumping up and down from 700-1300. i remember reading that I need to get something clean near the throrrle but i forgot what it was. can anyone help me out here?
Old Jun 6, 2007 | 03:23 PM
JjuuN R's Avatar
Stock R?
Old Jun 6, 2007 | 10:18 PM
itr1244's Avatar
Default Re: (JjuuN R)
if you find out. let me know what it was
Old Jun 7, 2007 | 12:45 AM
Haleiwa-Brando's Avatar
Default Re: (itr1244)
More info on what it's doing and the condition of the car would help. This topic has come up many times in the past as well.
Is it getting spark? Is it getting fuel? If so...how did you test this?
Old Jun 7, 2007 | 01:30 AM
rjgerolaga's Avatar
idle valve (aicv) went out. possibility.
Old Jun 7, 2007 | 06:11 AM
Chump2515's Avatar
Default Re: (rjgerolaga)
happned to my car and my dads, we cleaned out the injectors and the engine wasnt getting enough fuel.
dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">Is it getting spark? Is it getting fuel? If so...how did you test this?</TD></TR></TABLE>
Old Jun 7, 2007 | 06:13 AM
97CWITR's Avatar
Default Re: (Chump2515)
clean out the idle air control valve behind your intake manifold with brake cleaner. Start with the cheap things first.
Old Jun 7, 2007 | 06:20 AM
AlienKrOZ's Avatar
Default Re: (97CWITR)
car is bone stock starts and drives. the idle either stays at 1300 or 700 after it's warmed up. sometimes it can be 700 and next stop light be 1300. or it can just raise from 700 to 1300 or drop from 1300 to 700 in a second. it does not keep jumping up and down back and forth. just moves a bit once in a while.
Old Jun 7, 2007 | 06:48 AM
itrSteez's Avatar
Try a new TPS sensor, I've seen it happen many times. Same symptoms.
Old Jun 7, 2007 | 07:46 AM
vinuneuro's Avatar
Default Re: (itrSteez)
1. Vacuum leak
2. Fast idle valve, Idle Control Valve
3. Air in coolant
4. TPS
Eddog85
Dec 30, 2008 04:42 AM
Froch
Jan 13, 2008 12:16 PM
I Like Hondas
21
Jul 24, 2006 08:54 PM
TheWelderGuy
Apr 2, 2006 10:24 AM
Accelerated
Mar 25, 2002 06:45 PM
