HELP W/ Idle problems
Old Mar 24, 2002 | 08:31 PM
Accelerated's Avatar
Default HELP W/ Idle problems
When the car is cold, it will idle GREAT.
Once she warms up, it won't hold an idle at ALL. YOu have to keep accelerator pressed down to keep it running.
I've replaced the IAC, and the IDLE control valve under the TB. No codes at all. What gives?
Old Mar 25, 2002 | 06:45 PM
ELUD THS's Avatar
New User
Default Re: HELP W/ Idle problems (Redline_Engineering)
hmm good question, i was going to say check the fast idle valve, then see what codes if it is throwing nay out. there might be some gunk built up in the fuel injectors thaT MIGHT BE CAUSEING it to not idle. at cold temp, the car has a constant flow of gas , but when it warms up if theres gunk in the injectors it might be preventing a consistant flow of gas.
typer_696
Aug 8, 2009 01:43 PM
mikeunreal2
11
Mar 23, 2006 12:00 PM
hondachris1994
10
Feb 25, 2006 02:37 PM
ick
Sep 11, 2005 10:46 PM
