Removing A/C, quick question..
Old Nov 17, 2003 | 12:42 PM
mstewar's Avatar
Default Removing A/C, quick question..
Most of the a/c components were not in the car when I got it. The only thing I can tell that's still in it, that's part of the system, is the evaporator. Never pulled one on a functioning/running car and just wanted to make sure it wasn't needed for any other part of the HVAC system than the a/c. Thanks!
Old Nov 17, 2003 | 12:57 PM
Drive01's Avatar
Default Re: Removing A/C, quick question.. (mstewar)
no, if no AC, then you don't need it. You might be able to shell it out by opening it up and pull the evaporator out. But what I did was get the ducting from a Civ or Integ w/ out AC, and replaced the section. But you do need something there to connect the fan to the rest of the hvac system.
Old Nov 17, 2003 | 01:04 PM
mstewar's Avatar
Default Re: Removing A/C, quick question.. (Drive01)
ah.. so i can't just pull the big hulking black and white plastic thing out and expect to still be able to use the heat? unless I take it out, remove the evaporator from inside, and then reinstall or something?
Old Nov 17, 2003 | 03:48 PM
Art Vandeleigh's Avatar
there is still a LITTLE bit of heat that comes out of the vents but just barely. i have been meaning to get the duct but have been too lazy. how much does one of those things cost anyway?
Old Nov 18, 2003 | 05:44 AM
mstewar's Avatar
Default Re: Removing A/C, quick question.. (Art Vandeleigh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art Vandeleigh &raquo;</TD></TR><TR><TD CLASS="quote">there is still a LITTLE bit of heat that comes out of the vents but just barely. i have been meaning to get the duct but have been too lazy. how much does one of those things cost anyway?</TD></TR></TABLE>
so basically, without the duct that surrounds the evaporator, you get no pushed air.. that's why it's just a trickle of heat. got it..
Blacknight117
Aug 15, 2011 07:48 PM
slickciv
Jul 6, 2006 09:35 AM
ROOROWNS
Feb 14, 2005 01:00 PM
mamaboy
11
May 25, 2004 05:07 PM
POS89CivicLX
Jun 12, 2002 09:40 AM
