relocating the abs unit?
ok well i just repainted my car inside and out and the engine bay looks so nice without the abs unit in there. the problem is i want abs in my car! if i was to relocate the abs pump to the trunk area using stainless steal lines or custom hardlines, would it still function the same?
im looking for a itr ABS unit.
Re: relocating the abs unit? (Darkness...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkness... »</TD></TR><TR><TD CLASS="quote">*puts flame retardant suit on for xdriver*</TD></TR></TABLE>
thanks darkness! i know i need it for this one! it was only a thought though.
Modified by xdriver at 10:29 PM 10/17/2004
Re: relocating the abs unit? (xdriver)
yea i have been wondeirng the same thing.. also do you know if the 98-01 ABS pumps are compatiable with the 94-97 ABS comp??? if they are not, are the comps. swap and play or do you have to tinker with the wiring harness to re-wire??
reasoni want to know this is, b/c the 98-01 ABS pumps are much smaller in size and lighter and i have one sitting here... my car is a 97 so i was wondering about compat. problems with my 97 ABS comp with a 98-01 ABS pump..
Re: relocating the abs unit? (manikgsr)
it should be a direct swap! the itr abs unit is different from the gsr. from what ive read and researched, the itr abs unit is better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdriver »</TD></TR><TR><TD CLASS="quote">it should be a direct swap! the itr abs unit is different from the gsr. from what ive read and researched, the itr abs unit is better.</TD></TR></TABLE>
is the comp. itself better or is the ITR pump better then the 98+ gs-r?? or both??
