Question for those who have removed their a/c system...
Rather OG
Does anyone have the part number for the plastic shield which goes that attaches to the radiator? I know many have attested to seeing lower water temps after installing this. Any help would be greatly appreciated. Thanks!
[Modified by Jason Franza, 10:22 AM 9/29/2002]
Re: Question for those who have removed their a/c system... (baonest)
I think he's talking about a plastic shield that would cover where the condenser fan is. Since you had factory a/c you won't have it.
Re: Question for those who have removed their a/c system... (sackdz)
thanx
Rather OG
Re: Question for those who have removed their a/c system... (Johnny Tran)
give me sizes/dimensions.....i will make you one out of sheetmetal for vir. c00l factor of 10
Re: Question for those who have removed their a/c system... (Jason Franza)
Nice! I was considering purchasing one if it could be had for cheap. Otherwise, I was just going to fab something myself
Re: Question for those who have removed their a/c system... (IntyTypeR0798)
does it really lower water temp that much? i had my a/c removed as well and i dont have that square where the condenser fan was covered at all.
Rather OG
Re: Question for those who have removed their a/c system... (CART fan)
Mine isn't covered either, which is why I'm going to cover it
I've heard from credible sources that say they've seen anywhere between 30 and 40 degree variance in temperature
I had to remove my AC condenser to fit my Koyo radiator, so no AC for me either. Does anyone have pics of this piece Jason is talking about?
Re: Question for those who have removed their a/c system... (Christian)
yeah, need pics, that would be sweet. this is a good idea. i wouldnt mind a drop of 30 degrees or so in water temp. anyone got a pic or an idea of how to fab this piece?
If you are taking about a EG body that has had the a/c removed...
https://honda-tech.com/zerothread?id=103429
If you are taking about a DC2 body...
38623-P72-900 = "radiator side seals"
They will not help keep the car cool with the a/c removed.. only help the fans draw more air thru the condenser.
Re: Question for those who have removed their a/c system... (Project X)
did you just splice the wire into the cooling fan from the a/c fan. that seems like reasonable idea. should be easy right?
You can always rewire the A/C fan to go on w/ the rad fan. That way, you have dual fan for the rad. That will sure cool the water temp down. That's what I did for mine after I removed the A/C.
I believe that "sheild" is for the Bseries with the small Half sized radiators, like in hatches.. Look into it on the parts sheets for 1993 civic hatch without AC, I would think....
Re: Question for those who have removed their a/c system... (Honda318dx)
they are sadly mistaken, tell your source to do more of their homework.
I shoot brides
Re: Question for those who have removed their a/c system... (Willard)
[QUOTE]If you are taking about a EG body that has had the a/c removed...
pix don't work
pix don't work
Rather OG
Jason-
who has a plan for some good stuff, and will be getting ready for possible H1 entry next year...
[Modified by Jason Franza, 1:04 PM 9/30/2002]
Re: Question for those who have removed their a/c system... (yoshi234)
pix don't work
http://www.imagestation.com/picture/...a.jpg.orig.jpg
http://www.imagestation.com/album/?id=4292758871
[Modified by Willard, 1:00 PM 9/30/2002]
Rather OG
Re: Question for those who have removed their a/c system... (B18CXr)
LOL, if you only knew...
why remove the full width unit?
so how would you mount that to the ITR radiator. looks like an abs plastic sheet to me? will, whats it made of?
