Question : B18C
Old Sep 27, 2003 | 01:14 PM
CunninLynguist's Avatar
Default Question : B18C
Please tell me the number that corrisponds to the parts listed below.
a. Vtec solunoid.
b. Vtec oil pressure switch.
thanks for the help.
Modified by Scot project at 9:58 PM 9/27/2003
Old Sep 27, 2003 | 01:18 PM
92TypeR's Avatar
FSAE
Default Re: Question : B18C (Scot project)
VTEC Soleniod is 14, and the pressure switch is 15 I believe...its hard to tell from the diagram.
Old Sep 27, 2003 | 01:40 PM
Default Re: Question : B18C (92TypeR)
First - I am trying to put a jspec b18c into my 92 cx.
Almost everyone on this board says i need a vtec solenoid but from the pic below i already have that.
This is a pic from my engine and to me that mean's i am missing the pressure switch.. Is that correct?
Can i just buy a switch and put it in?
Old Sep 27, 2003 | 02:17 PM
IGGY's Avatar
It looks like the switch can go where that plug is in the pic.
Old Sep 27, 2003 | 02:18 PM
92TypeR's Avatar
FSAE
Yes, you already have the solenoid.
JDM engines do not have an oil pressure switch. The JDM ECU's do not look for it, so even if you have it, nothing will happen.
Unless you are using a USDM ECU, there is no need for it, but i do not know about Euro ECU's if they look for the pressure switch or not...
Old Sep 27, 2003 | 08:58 PM
Does anyone know if i can just buy the switch and install it with out a new Assembly
Old Sep 27, 2003 | 09:25 PM
splitime's Avatar
I run the jdm vtec solenoid and no pressure switch, just wire them together at the ecu.
Old Sep 27, 2003 | 09:40 PM
Nameless RB26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot project &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if i can just buy the switch and install it with out a new Assembly</TD></TR></TABLE>
no you can't..
I have a complete vtec solenoid and switch assembly for sale for 30$ shipped if you want it.
Old Sep 28, 2003 | 01:44 AM
GokuSSJ4's Avatar
Default Re: Question : B18C (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">I run the jdm vtec solenoid and no pressure switch, just wire them together at the ecu.</TD></TR></TABLE>
with this i have to check mine , does it matter if you run a p28 ecu or not ?
Old Sep 28, 2003 | 08:47 AM
splitime's Avatar
Default Re: Question : B18C (Spoon1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon1 &raquo;</TD></TR><TR><TD CLASS="quote">
with this i have to check mine , does it matter if you run a p28 ecu or not ?</TD></TR></TABLE>
Good question, can't really answer that considering i'm running a p28. I'd assume it would read the same if it wasnt a p28, as long as both vtec wires are joined. Its basically tricking the ecu.
Old Sep 28, 2003 | 09:52 AM
Good question, can't really answer that considering i'm running a p28. I'd assume it would read the same if it wasnt a p28, as long as both vtec wires are joined. Its basically tricking the ecu.</TD></TR></TABLE>
How does this effect your driving? Wont vtec engauge even if your oil pressure is not enouph?
Car: 92cx
ecu: kenji p28
Old Sep 30, 2003 | 02:15 PM
splitime's Avatar
Think about it this way. What is the setup on the JDM engine.... ecu taking readings and only plugged into the Solenoid. So what is the issue with tricking the usdm ecu into doing the same, just activating when you tell it. The splice is just fooling the ecu into not throwing a code anyways.
think about it.
Old Sep 30, 2003 | 02:21 PM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">Think about it this way. What is the setup on the JDM engine.... ecu taking readings and only plugged into the Solenoid. So what is the issue with tricking the usdm ecu into doing the same, just activating when you tell it. The splice is just fooling the ecu into not throwing a code anyways.
think about it. </TD></TR></TABLE>
The car feels great (splitime's car), and no issues with VTEC.
Personally I'd do it the same way he is explaining.
Old Oct 1, 2003 | 02:56 AM
Default Re: Question : B18C (Chris N)
Or just spend the 30$ and get a used switch/solenoid assembly
Old Oct 1, 2003 | 06:04 AM
mstewar's Avatar
Default Re: Question : B18C (Nameless EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 &raquo;</TD></TR><TR><TD CLASS="quote">Or just spend the 30$ and get a used switch/solenoid assembly </TD></TR></TABLE>
why? no need.. basically throwing away $30..
Old Oct 1, 2003 | 06:33 AM
splitime's Avatar
Default Re: Question : B18C (mstewar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">
why? no need.. basically throwing away $30.. </TD></TR></TABLE>
exactly, 30-50bucks or just .02 of wire and 5minutes to solder/tap it.
Old Oct 1, 2003 | 07:54 AM
Chris N's Avatar
why? makes no sense.
Cjkelley87
Apr 15, 2012 05:08 PM
pkolaboy
May 28, 2008 05:43 AM
Double_Trouble_99
Apr 17, 2008 01:02 PM
94BlackRS
Jun 30, 2003 06:43 AM
EKen9
16
Jul 19, 2002 02:43 AM
