Project Ls/R
Old Feb 15, 2008 | 08:56 PM
jsen93ITR's Avatar
Default Project Ls/R
so i have a 93 integra ls 4dr, and i am planning to buy a b18c-r this coming summer, i want to change all the internals before dropping it in, it would help if you would be able to help me out on what different components you put in the engine and how well it has performed on a rate of 10, and in 2009 i plan on buying a turbo kit, i wanted a supercharger but for the money to horsepower, its not worth it,
so i came up with a little list of the things i want to have in it,
Spoon sports piston w/ rings kit
Metal head gaskets
AEM High Volume fuel rails
Pulstar Pulse Spark Plugs
Thats about it for now
Old Feb 15, 2008 | 09:07 PM
Jpres927's Avatar
Default Re: Project Ls/R (jsen93ITR)
jasma parts are all 10's!!
Old Feb 15, 2008 | 10:46 PM
John M's Avatar
Old Feb 15, 2008 | 11:31 PM
neo_'s Avatar
Default Re: Project Ls/R (John M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsen93ITR &raquo;</TD></TR><TR><TD CLASS="quote">help me out on what different components you put in the engine and how well it has performed on a rate of 10.</TD></TR></TABLE>
LOL, WTF?
and in 2009 i plan on buying a turbo kit, i wanted a supercharger but for the money to horsepower, its not worth it, </TD></TR></TABLE>
a) Don't turbo a Type R engine.
b) Understand the pros and cons of superchargers and turbos. Hint: Power band vs peak power - which is best suited for your intended vehicle use.
c) Do you even understand what kind of an application the pistons you listed below are designed for? Defiantly not boost. Read on to find out some more about your Spoon piston selection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsen93ITR &raquo;</TD></TR><TR><TD CLASS="quote">so i came up with a little list of the things i want to have in it,</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsen93ITR &raquo;</TD></TR><TR><TD CLASS="quote">Spoon sports piston w/ rings kit</TD></TR></TABLE>
Just one Spoon piston, huh? Do you understand the fact that Spoon pistons are nothing more then OEM JDM ITR Pistons? Spoon buys lots of pistons from Honda, then matches up the closest weighing pistons and sells it in a set. This balance is designed for road racing where reliability depends most.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsen93ITR &raquo;</TD></TR><TR><TD CLASS="quote">Metal head gaskets </TD></TR></TABLE>
Most, if not all head gaskets are metal. BTW, you only need one. Not two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsen93ITR &raquo;</TD></TR><TR><TD CLASS="quote">AEM High Volume fuel rails</TD></TR></TABLE>
You only need one fuel rail. Not two. OEM fuel rails are sufficient up to around 500 WHP, and even then you won't benefit from one unless you run new bigger lines from the pump to the fuel filter/fuel rail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsen93ITR &raquo;</TD></TR><TR><TD CLASS="quote">Pulstar Pulse Spark Plugs</TD></TR></TABLE>
Stick to NGK's. And don't list Spark Plugs as a mod, that is idiotic. Are you going to list your oil brand as a mod too? How about your tire pressure PSI?
BTW, <FONT SIZE="8">GTFO</FONT>
Modified by neo_ at 3:52 AM 2/16/2008
Old Feb 15, 2008 | 11:36 PM
R-box's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
super -
Old Feb 15, 2008 | 11:47 PM
JjuuN R's Avatar
Default Re: Project Ls/R (R-box)
IBTL
Haleiwa-Brando's Avatar
OP: All though you may be all excited about your project and what not, the reality of it may not be what you are looking for. Ask yourself:
Are my funds in place?
What if something goes wrong with the build, how will I drive myself to work/school/etc?
What do I want to do with the car? Auto-X, HPDE, Track *****, DD?
Simply from what you have written it sounds that you have quite a bit of learning and reading to do. Don't fret though. We all have to learn some time. None of us are born being automotive geniuses. Well...some of us I kid...I kid. I strongly suggest that you research this a bit more on your own before jumping on an internet forum to ask for help on parts that you may not know much about. Now hop to it!
Turbo charging a stock B18C5 is not so much of a good idea. Don't ask me how I know.
Old Feb 16, 2008 | 10:21 AM
SuckMyDOHC's Avatar
so you do know that the motor itself will be worth more than your car, right?
Old Feb 16, 2008 | 10:45 AM
Comp97GSR's Avatar
Default Re: (SuckMyDOHC)
IDB ftw
Old Feb 16, 2008 | 11:37 AM
meots98itr's Avatar
Default Re: Project Ls/R (Haleiwa-Brando)
i dont think its my funds in place.
i think is my homies in place and ready to jack an r to put on his 4dr ls.
Old Feb 16, 2008 | 05:24 PM
silver j's Avatar
Default Re: Project Ls/R (meots98itr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meots98itr &raquo;</TD></TR><TR><TD CLASS="quote">i dont think its my funds in place.
i think is my homies in place and ready to jack an r to put on his 4dr ls. </TD></TR></TABLE>
that hurt my brain
Old Feb 16, 2008 | 06:05 PM
jsen93ITR's Avatar
okay sorry that i put "s" on the end of some words, its a common mistake, and why do you think i made this forum, so i can get more info on parts that i came across buddy, the whole purpose of this is that i can get some more information before i do this, i have read forums on superchargers vs. turbo's, even tho i dont know everything that why i asked, im not gonna come across and pretend like i know everything, i also do understand how much the engine costs, why do you think i am getting it in the summer and not putting it in for another year, i wasnt born yesterday
Old Feb 16, 2008 | 10:08 PM
97 TYPE-R 312's Avatar
Please search for your answers.
Thank you!
jsen93ITR
Feb 15, 2008 07:05 AM
Raul
Mar 6, 2006 03:50 PM
tegrunner
Dec 29, 2005 09:44 PM
Dc2 Powered
Aug 8, 2003 11:17 PM
EG dreams
Dec 1, 2002 09:44 PM
