Problem help!!
Old Aug 1, 2001 | 11:46 PM
JDM R98's Avatar
Default Problem help!!
Hi..I am running rich..what can i do to stop it from running rich?what would happen if my car run rich?plmk..thanks
Old Aug 1, 2001 | 11:50 PM
Type Goch's Avatar
New User
Default Re: Problem help!! (JDMR98)
i doubt anything bad would happen other than a loss of power. If you have a VAFC why not control it?
Old Aug 2, 2001 | 12:14 AM
yellow blur's Avatar
Default Re: Problem help!! (Type Goch)
I guess you could lean out the fuel with the VAFC that goch said you have, but the only real way I think is going on a dyno to get maximum fuel/power efficiency.
Do a search, i think the topic of running rich/too much fuel has come up a few too many times.
Old Aug 2, 2001 | 12:23 AM
JDM R98's Avatar
Default Re: Problem help!! (yellow blur)
Do i lose alot of power?and where is a place i can get a cheap vafc at?thanks
Old Aug 2, 2001 | 12:25 AM
Type Goch's Avatar
New User
you can try diabloautosports.com i think they have one on sale for about 299 or 300 bucks..When you run too rich i think there's a significant power loss. BTW,,how are you running too rich?
Old Aug 2, 2001 | 12:26 AM
JDM R98's Avatar
instead of a vafc how about a field vtec controler will that work?and how do you lean it out at wat settings..You guys thinking i am losing alot of power?plmk..thanks
Old Aug 2, 2001 | 12:27 AM
JDM R98's Avatar
i see black smoke a little bit
Old Aug 2, 2001 | 12:30 AM
fields vtec controller is exactly that, a vtec controller, it does not have the ability to modify fuel like the v-air fuel controller, (if i remember correctly.)
Type Goch's Avatar
New User
hmm are you seeing a little black smoke around Vtec range? If so, a little black smoke is normal in that area..
Old Aug 2, 2001 | 12:31 AM
JDM R98's Avatar
yeah in vtec range
Type Goch's Avatar
New User
a little black smoke isnt bad..our R's come slightly rich from the factory..if your car is stock and its doing that, i wouldnt worry about it.
Old Aug 2, 2001 | 12:32 AM
JDM R98's Avatar
thanks goch ..almost scare there that i am losing power cause i have a big event that is coming up and cant afford to lose power due to runing rich..thanks
btw what u think about the field sfc vtec controller or the afc what the diff?
Old Aug 2, 2001 | 12:34 AM
AJ PwR's Avatar
have your car dyno and hook up with the wide band O2 then u'll get the acurate numbers.
Old Aug 2, 2001 | 12:35 AM
Type Goch's Avatar
New User
i havent seen much comparison between those two. I think both of them can get the job done. Maybe one of them have more functions or capabilities. Your engine IS stock right?
Old Aug 2, 2001 | 12:37 AM
JDM R98's Avatar
yeah just intake/headers/test pipe/2.5" custom piping w/ free flow magna flow exhaust with 2.5" outlet and inlet
Old Aug 2, 2001 | 12:38 AM
Type Goch's Avatar
New User
I think you're safe.
JDM R98's Avatar
thanks Goch
Old Aug 2, 2001 | 12:39 AM
Type Goch's Avatar
New User
no prob.
01ITR#173DC2ning
Mar 3, 2006 06:15 PM
BDTURBO
Feb 27, 2003 10:56 AM
sslude
Jan 5, 2003 01:49 AM
gspeedline228
Oct 25, 2001 09:25 PM
gspeedline228
Oct 25, 2001 06:56 PM
