preload
Old May 13, 2003 | 03:47 PM
RiCE On IcE 2's Avatar
Default preload
Anyone have a pic of the lower adjustment bracket on say a B6... I'm just curious how it works in regard to preload... and I have yet to be able to get a good look at it.
Old May 13, 2003 | 03:49 PM
Reid's Avatar
Global Moderator
Default Re: preload (RiCE On IcE 2)
Just leave the B6's alone and install them.
They come preset.
Do not worry about preload since you apparently think it has something to do with the type of suspension you have, rather than a spring.
EDIT:
Not directed at you, but:
Why do people want to get suspension with as many adjustments as possible if they do not know what to do with the adjustments? It's far easier to do harm than good.
Old May 13, 2003 | 03:56 PM
Asahi's Avatar
Default Re: preload (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Just leave the B6's alone and install them.
They come preset.
EDIT:
Why do people want to get suspension with as many adjustments as possible if they do not know what to do with the adjustments? It's far easier to do harm than good.</TD></TR></TABLE>
That said, could someone who did put the a set of B6's on and finds them to understeer even at the most radical shock settings. Is it possible to adjust preload to change this behavior?
Trey
Old May 13, 2003 | 04:00 PM
Big Phat R's Avatar
Default Re: preload (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">
Trey</TD></TR></TABLE>
Understeer is largely related to the relative spring rates F/R. Adjusting the dampers to the "most radical shock setting" can make a spring seem stiffer - but at the expense of proper damper function (i.e. overdamped = bad)
Old May 13, 2003 | 04:01 PM
They come preset.
EDIT:
i don't have a set of b6's not plannign on a set either was prolyl gonna get the b2's I was jsut curious how that lower bracket was able to adjust preload. on the b6 and above
Old May 13, 2003 | 04:02 PM
Reid's Avatar
Global Moderator
If you need to add significant preload to a spring, it is a sign that you should move up to a spring with increased stiffness.
What are your current rates, thread hijacker?
Old May 13, 2003 | 04:05 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiCE On IcE 2 &raquo;</TD></TR><TR><TD CLASS="quote">
i don't have a set of b6's not plannign on a set either was prolyl gonna get the b2's I was jsut curious how that lower bracket was able to adjust preload. on the b6 and above</TD></TR></TABLE>
Spring preload is used to setup a spring for slightly increased stiffness.
As stated above, it is a better choice to use stiffer springs rather than try to add preload.
Too much preload just places more burden on the shocks.
Adjustable spring perches give one the ability to play with spring preload.
Old May 13, 2003 | 04:50 PM
.RJ's Avatar
.RJ
Preload wont affect spring rate or how the car feels on track - other than the fact that you can use spring preload to cornerweight the car. And if your shock is ride height adjustable, thats the *only* reason to touch the spring preload perch.
RJ - who agrees that too many adjustments is a bad thing, and hasnt touched his shocks since VIR in february
Old May 14, 2003 | 03:55 AM
Asahi's Avatar
Default Re: preload (Big Phat R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">
Understeer is largely related to the relative spring rates F/R. Adjusting the dampers to the "most radical shock setting" can make a spring seem stiffer - but at the expense of proper damper function (i.e. overdamped = bad)</TD></TR></TABLE>
WHen I said most radical I meant front settings as soft as possible and rear as stiff as possible to purposely overdame the rear to reduce traction. The Theory that has worke don all my other shocks just didn't seem to work this last time I was racing.
Trey
Old May 14, 2003 | 03:56 AM
Asahi's Avatar
What are your current rates, thread hijacker? </TD></TR></TABLE>
My current rates are 10/6 (Street). I have considered going to a 12kg/mm rear spring.
Trey
Old May 14, 2003 | 03:58 AM
Asahi's Avatar
the B6's have a spring perch that casn change the preload on the spring like you mentioned. There is then a mount that will allow the height of the shock to be adjusted without allowing the preload or the stroke of the shock to be changed. YOu really should see a shock to better undrestand thes. The mounting backet is threaded and allows the shock to spin down into it.
Trey
DG-FNR
10
Sep 7, 2008 06:14 PM
cloudx71
Sep 30, 2005 10:47 PM
tianporn
Suspension & Brakes
Jun 19, 2005 09:24 AM
CRXSiR71777
Jan 24, 2005 05:52 PM
