Please help brake problem!!!
Old Sep 30, 2002 | 02:37 PM
erikgsr's Avatar
New User
Default Please help brake problem!!!
I am hoping some of you guys can help me. I am changing the rear pads on my car. I disconected the caliper, and tried every tool known to man, to push the piston back, to make the new pads fit. Ive been doing this for the past 4 hours, half of the time going to auto zone to buy different c-clamps. Can anyone give me a tip on how to do this. What am doing wrong???? I have changed my front pads before, and it was not this hard. Please Help, thank you in advance
Erik
Old Sep 30, 2002 | 02:40 PM
Smitdog's Avatar
Default Re: Please help brake problem!!! (erikgsr)
Ummm............. you turn them back in not just push them in with a C Clamp!!
Special tool needed!
[Modified by Smitdog, 11:40 PM 9/30/2002]
Old Sep 30, 2002 | 02:43 PM
XR4racer's Avatar
screw-in... using the slots.
Old Sep 30, 2002 | 02:44 PM
erikgsr's Avatar
New User
Default Re: Please help brake problem!!! (Smitdog)
You mean those grooves on the piston, are meant for a tool. So the piston needs to be turned? Is there any other way to do this?
Old Sep 30, 2002 | 03:12 PM
99MR_SiR's Avatar
yes take a flat head screwdriver or anything flat and strong enough to turn it back in. ..... problem solved.
Old Sep 30, 2002 | 03:19 PM
ITRmike98's Avatar
Default Re: Please help brake problem!!! (99MR_SiR)
use a small prying bar type tool....that seems to work
Old Sep 30, 2002 | 03:23 PM
erikgsr's Avatar
New User
Default Re: Please help brake problem!!! (ITRmike98)
I am doing the side with the parking brake.. Does that make a difference?
Thank you for the help, for those who replied.
erik
Old Sep 30, 2002 | 03:26 PM
Cosworth's Avatar
go to autozone, pepboys, buy a HUGE screw driver and turn those suckers until it's pushed it.... rear pads are a bit more pain in the ***.
Old Sep 30, 2002 | 05:11 PM
EleanoR's Avatar
Default Re: Please help brake problem!!! (Cosworth)
Cosworth is right. They are more of a pain in the ***. There is a tool that you can buy (i finally did) at Pep Boys, AutoZone, or Discount Parts that is made for compressing the piston back in to accomodate new brake pads. It was only $10. It is a block shaped tool that fit's a 3/8 ratchet and you just fit the little grooves of the tool into the piston and turn away
be sure to turn the piston to the right to compress and have at it!
Mike
Old Sep 30, 2002 | 06:24 PM
erikgsr's Avatar
New User
Default Re: Please help brake problem!!! (EleanoR)
Yeah, i saw that square tool just now, looks like im going to the store tommorow morning, i just hope they are universal.
mainah
13
Aug 18, 2009 02:10 PM
brixity
Mar 27, 2009 04:39 PM
elmalouno
Aug 25, 2004 01:46 PM
ACIN
Dec 9, 2001 05:39 AM
