Pedal Extentions?
Accident Prone
1 Post
Pedal Extentions?
So after my first track day this past Friday, I was disappointed in my inability to heel toe for these reasons:
1. The pedals were too far apart for a side-by-side action
2. My knee would bang the bottom of the steering wheel hub if I tried to do it the heel-toe way
3. If I moved the seat back, I would not be in a good driving position (I have long legs and relatively short arms)
I talked to a few other drivers and they suggested these things:
1. Getting a racing seat that places me lower in the car
2. Getting a racing steering wheel with a smaller-diameter steering wheel hub so when I twist to heel-toe, my knee has more room to maneuver
3. Getting different pedals/gas pedal extension so I can side-by-side
I don't want to do 1 or 2 because of cost and the supporting modifications needed. So now I'm stuck with option 3: different pedals/gas pedal extension.
I talked to the son of one of the instructors at the event and he said that getting a pedal set won't really work because the pedals in the Integra are fairly far apart to do side-by-side so if the new pedals aren't much wider than the stock, it would be a waste of money. So now I'm left with gas pedal extension such as this (for the Miata): http://www.flyinmiata.com/index.php?...umber=21-74900
My question: where to find one of these for the Integra's gas pedal? I've also read that the Mugen set actually has a wider gas pedal so that would help?
Re: Pedal Extentions?
Pedals in an Integra are not far apart. Pedals in a Prelude are much more apart and somewhat difficult to heel-toe.
How tall are you? I'm ~5'11" and have zero issues with stock pedals, especially if you put pedal covers on them (mugens are pretty nice).
What I did to deal with the knee issue was a combo of 1 & 2. Lower seat, smaller wheel, AND a wheel spacer/quick release. That pushed the steering wheel about 2.5" closer to the driver. That allowed me to sit further back, not stretch my arms, and my legs are in a better position as well.
I would not go the pedal extensions route.
Accident Prone
1 Post
I'm about 5'9" but my legs from waist down is 3'4" and my arms from shoulder to middle fingertip is ~2'7.5"
The only reason I don't want to do 1 and 2 is that I'd like to keep my car stock interior because if I don't intend on making it into a strict track car
If I didn't want to get a lower seat + different steering wheel, would just Mugen pedals work (for side-by-side)?
I have the same problem being 6'3". I can heel toe pretty good if I move the seat far back but then I am not in the ideal position to turn and shift. Being strapped into a harness or with your shoulders against the seat your wrists should sit on the top of the wheel. I just need a wheel or hub that pushes it out farther. I think the stock wheel is a 350mm isnt it?
You don't have to completely rotate the bottom half of your leg at the knee to heeltoe. Theoretically I guess it's safer that way as you get to cover the brake pedal more. When I'm lazy I can still do it while my foot is still almost straight, in my ITR or otherwise.
Daisy... Daisy...
What brakes are you running? I was having trouble because the brake pedal was sitting too low with hot Hawk HPS pads. I will have HP Plus for the next track event.
I had a difficult time learning and felt like it was the pedals. Also my knees hit the steering column. I made new pedals from aluminum, jpeg included. The screws clamp the pedals and they have been in place for years. This made it easy, though I could probably do with normal pedals now as I can heel toe or roll my foot on other cars. These extensions were simple with aluminum and a band saw, then some abrasive for texture. The attachments are like original, take off the rubber covers. Sorry for the poor photo, the car is in the garage on a rainy day, so poor lighting.
Try skateboard tape.
However, you might want to make sure your TPS sees 100% because that pedan looks long and might not go down all the way and get stuck in the carpet.
Daisy... Daisy...
The Mugen pedals are very nice. My problem was that I had to reach back for the gas pedal once the HPS pads got hot because the brake pedal was riding lower. I still had plenty of stopping power, I just had to push harder.
Accident Prone
1 Post
Lol I love my HP+. Very grabby on the street but man oh man, on the track they could bring me from 120 to 90 in less than the distance between 2 braking cones.
I made the pedal long, and then cut it off to fit. It works with floor mats out and that is how I run HPDE. It can stop slightly short of full throttle on the road, stopped by the mats.
ken_shields
01-29-2013 09:04 PM
quickster
11-11-2010 06:29 AM
