>>>>>overheating issue<<<<<
Old Nov 6, 2008 | 06:52 PM
CarbonfiberR's Avatar
Default >>>>>overheating issue<<<<<
The problem I am having is after my car is running after a while it starts to overheat. The fans werent coming on so i unplugged the fan switch that is on the thermostat housing and jumpered the two plugs. the fans came on so i thought problem solved i just need to replace that switch. well the fans now are always on and the car still overheats. Any ideas?
Old Nov 6, 2008 | 07:04 PM
99SlammedCivic's Avatar
Snipper Snapper
Default Re: >>>>>overheating issue<<<<< (CarbonfiberR)
New thermostat / head gasket
Old Nov 6, 2008 | 07:20 PM
Mr.OB*GYN_Rhett's Avatar
try bleeding the system, start your caR with the radiator cap off til it reaches operating temp. if it still happens its the thermostat
Old Nov 6, 2008 | 08:53 PM
Kavehman's Avatar
I thought the thermostats get stuck in the open position on Honda's ??
I would say its air in the system, my car would take ages to warm up, i think it was air in the system cause the problem has gone.
Old Nov 6, 2008 | 09:14 PM
cxSHOE's Avatar
rent a "block tester" and buy the liquid, follow instructions and this will tell you if you if you have a bad headgasket without removing the head.
Old Nov 7, 2008 | 03:53 AM
walker111's Avatar
Default Re: (Kavehman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">I thought the thermostats get stuck in the open position on Honda's ??
I would say its air in the system, my car would take ages to warm up, i think it was air in the system cause the problem has gone.</TD></TR></TABLE>
Honda thermostats fail in the open position, meaning your car will never get to NOT if it takes a crap. I wouldnt point at a head gasket right off the bat, bleed/replace the coolant and see where that gets you.
Check your oil and make sure it looks like oil and not chocolate milk.
Old Nov 7, 2008 | 05:00 AM
thanks guys, i will try and bleed the system first. the other thing is that if i turn on the heater while i'm driving it will slowly go back down but eventually try to overheat again. looked at the oil looks good and my radiator is still full.
Old Nov 7, 2008 | 05:38 AM
walker111's Avatar
Default Re: (CarbonfiberR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonfiberR &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys, i will try and bleed the system first. the other thing is that if i turn on the heater while i'm driving it will slowly go back down but eventually try to overheat again. looked at the oil looks good and my radiator is still full.</TD></TR></TABLE>
That is normal.....if your car ever overheats you should turn your heat on full blast and get some of that heat outta there.
Old Nov 7, 2008 | 05:57 AM
I just tried to bleed the system and no air bubbles but the car tried to over heat. What i did notice is that the lower radiator hose was completely cold and the upper was hot. Can it be that the thermostat is stuck closed not allowing coolant to go thru?
Old Nov 7, 2008 | 07:04 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonfiberR &raquo;</TD></TR><TR><TD CLASS="quote">I just tried to bleed the system and no air bubbles but the car tried to over heat. What i did notice is that the lower radiator hose was completely cold and the upper was hot. Can it be that the thermostat is stuck closed not allowing coolant to go thru?</TD></TR></TABLE>
Possibly, replace it.
Old Nov 7, 2008 | 07:07 AM
Default Re: (walker111)
going to do it now, just waiting for the car to cool down.
Old Nov 7, 2008 | 07:11 AM
walker111's Avatar
Its not fun if you dont get burned.
Old Nov 7, 2008 | 09:48 AM
if you dont get burned or drop a little blood then your not a mechanic. but thanks for everyones comments, i just replaced the thermostat and problem solved. thermo switch is perfectly fine it just wasnt seeing any hot coolant so it wouldnt turn the fans on.
Old Nov 7, 2008 | 09:49 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonfiberR &raquo;</TD></TR><TR><TD CLASS="quote">if you dont get burned or drop a little blood then your not a mechanic. but thanks for everyones comments, i just replaced the thermostat and problem solved. thermo switch is perfectly fine it just wasnt seeing any hot coolant so it wouldnt turn the fans on. </TD></TR></TABLE>
Honda thermo? I def recommend getting one.
Old Nov 7, 2008 | 09:53 AM
yea paid $18 for it from acura. i guess the old one stuck closed.
Old Nov 7, 2008 | 09:54 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonfiberR &raquo;</TD></TR><TR><TD CLASS="quote">yea paid $18 for it from acura. i guess the old one stuck closed.</TD></TR></TABLE>
must not have been honda.
Old Nov 7, 2008 | 09:59 AM
why?
Old Nov 7, 2008 | 10:01 AM
walker111's Avatar
Because I have never seen a Honda thermo fail closed.
if you are talking about the old thermostat it was the one that came with the car when i bought the car from acura in 01. i have never changed it.
Old Nov 7, 2008 | 10:02 AM
walker111's Avatar
hrmm, right on
I guess I am the first
sloassSi
Apr 16, 2010 07:15 PM
BoostinEJ1
17
May 19, 2007 04:57 PM
PreIudeSI
Aug 24, 2004 09:55 PM
EGhatched
Mar 14, 2004 04:17 PM
ScubaStevo80
Oct 31, 2003 08:47 AM
