Ouch......
Old Feb 16, 2003 | 09:02 AM
RaVAGE00's Avatar
New User
Default Ouch......
"If you are going to get your standard cast iron road car flywheel lightened then be sure to take it to a proper vehicle engineer and not just your local machine shop. Take off too much material and it might be weakened so much that it explodes in use. Given that flywheels (at least in rear wheel drive cars) tend to be situated about level with your feet, it isn't worth the extra acceleration if you lose both feet when the ring gear comes out through the side of the transmission tunnel like a buzz saw at 7,000 rpm. There are plenty of ex racing drivers hobbling about on crutches who'll tell you that this can and does happen. On FWD cars the effects can even more unpleasant - a flywheel entering the cabin can give you a split personality starting from just below the waist that will put quite a crimp in your day"
This possible???? Having second thoughts about installing the TODA
Old Feb 16, 2003 | 09:04 AM
uNF$@#!'s Avatar
Default Re: Ouch...... (RaVAGE00)
actually i'd be more worried about who's riding shotgun, but yeah, fw's do explode rarely.
if your uber worried, put a scattershield around your transmission....better yet, around the firewall area.
remember, the motor is between you and a good part of the transmission.
[Modified by Soup ****, 1:07 PM 2/16/2003]
Old Feb 16, 2003 | 09:09 AM
RaVAGE00's Avatar
New User
Default Re: Ouch...... (Soup ****)
"scattershield around your transmission"
Whats this?
Old Feb 16, 2003 | 09:27 AM
BABY NSX's Avatar
Quit your fussing and install that flywheel
Old Feb 16, 2003 | 09:49 AM
Splat's Avatar
Collector-o-Guns and Drinker
Whats this?
This one's for a smallblock Chevy, but you get the idea. Bolts around the flywheel area to keep the chunks inside if it lets go.
Old Feb 16, 2003 | 09:59 AM
Tommy_Gunns's Avatar
On an ITR, the flywheel is lined up to the passenger. So put that bitch on and kill your guests
Old Feb 16, 2003 | 01:58 PM
GZR4DR's Avatar
Default Re: Ouch...... (Tommy_Gunns)
Unless your running 11's or faster, i wouldn't even give it a second thought. I have yet to hear about anyones flywheel exploding in a Honda even with the lightened pieces. BTW it is required for NHRA if you run 11's or faster.
Old Feb 16, 2003 | 02:07 PM
Dr Pooface's Avatar
Default Re: Ouch...... (GZR4DR)
There have been no reports of fw's exploading on this board in the two or so years I've been here.
Old Feb 17, 2003 | 08:51 AM
RaVAGE00's Avatar
New User
Default Re: Ouch...... (Dr Pooface)
Good enough for me... thanks..
Time to slap that beeeeaatch on !!!!!
Old Feb 17, 2003 | 08:57 AM
vtec.dc2's Avatar
Default Re: Ouch...... (Splat)
that piece doesn't look expensive - anyone knows where to purchase one?
Old Feb 17, 2003 | 09:04 AM
py1188's Avatar
Default Re: Ouch...... (vtec.dc2)
Looks like you may even be able to fabricate your own
thewrai6th
Nov 2, 2009 08:44 PM
Hassan'sRR
Oct 13, 2003 07:33 PM
ActiveAero
Dec 14, 2002 04:13 AM
LoudAccord
Jan 8, 2002 08:40 PM
ej20_chris
Sep 29, 2001 09:41 AM
