Open Ended Lug Nuts / Extended studs?
New User
I used to have some Kyokugen lug nuts and they worked great, but they got to be a pain in the *** after a while.. Who else makes open ended lug nuts of good quality? Also who makes extended studs?
Re: Open Ended Lug Nuts / Extended studs? (RTW DC2)
is there a reason to have opened ended as opposed to the regular closed lugs?
Austin
Re: Open Ended Lug Nuts / Extended studs? (itr206)
I highly recommend AGAINST skunk2 wheelstuds and lugnuts.
10 of the 20 on my car either siezed, galled, stripped or snapped.
Some within the first month.
I recommend ARP studs.
Jeff Sloan uses ARP extended studs. Alot of people complained about the skunk2 studs. I'll see if I have the topic saved.
Here you go, this link should work.
http://www.hybridautomotive.com/tech/arp_studs/
Re: Open Ended Lug Nuts / Extended studs? (sgT)
Really, what about their cams?
do they snapped as well?
whats your opnion?
thank you.
Re: Open Ended Lug Nuts / Extended studs? (AllMotorITR)
https://honda-tech.com/zerothread?id=288525
order a box of the "Extended Conical Seat Bulge Nuts ( Open End )" and use the stock studs.
There was mention (somewhere) of a CL-S/TL-S application (a little bit longer Honda stud) that could be used in a Intrgra hub...
Re: Open Ended Lug Nuts / Extended studs? (Willard)
you can just use oem honda lug nuts, work fine for me with my extended studs. From a 94 accord ex they are openended, just use a deep socket
i was told in order to change the weel studs you would need to replace the wheel bearings. could this be true?
ProFunction/GT Motoring
Re: Open Ended Lug Nuts / Extended studs? (eviltwin)
Re: Open Ended Lug Nuts / Extended studs? (9Grandr)
We were talking about skunk2 extended wheel studs, not the lug nuts. I don't think skunk2 makes any lug nuts?
Re: Open Ended Lug Nuts / Extended studs? (Mario)
right off the comptech website:
Made from 190,000 psi heat treated,
8740 chromoly steel. 12mm x 1.5 thread
Sized to fit Honda/Acura hubs without
modification. Sold in sets of 4.
Yeah WAI, Skunk2 does make dud nuts... Im two short now, the threads on them are stripped now... And they cost like 80 bucks... They are super light, but super cheap... And they also get scratched up easy(not that it matters to me). But for that price, these lug nuts should be top notch...
First skunk2 product that I have dissapproved.
Re: Open Ended Lug Nuts / Extended studs? (skunked)
102 bucks for a set of Lug Nuts, how long have you used the Buddy Club lugs??? I also use my skunk2's on the street, are you running your Buddy Club lugs on street and track?
TIA
TIA
what about these?
http://www.inlinefour.com/axulraclugnu.html
Re: Open Ended Lug Nuts / Extended studs? (dyverge1)
The Axas lugnuts from Inline are really good. I've had them for a few months now on my racecar, and they hold up to abuse well. I zip them on and off pretty often, and the anondizing is still there.
Warren
Warren
Re: Open Ended Lug Nuts / Extended studs? (GONG SHOW)
TIA
TIA
what about these?
I run the Axas on the street with skunk2 studs which suck I got five sets before I found 16 I could use
