offset...+30? is that ok?
Old Aug 8, 2004 | 07:37 PM
sittin on GOLD's Avatar
Default offset...+30? is that ok?
well am thinking of purchasing some wheels w/ that offset. to me, its sounds way off and will stick out, but the owner says he runs it jus fine. i jus want to verify. i know 35 is ok, but 30? thats pushing it...
Old Aug 8, 2004 | 07:39 PM
BolivianDc2's Avatar
Default Re: offset...+30? is that ok? (advertise)
thats too far out, +35 lines up dead even or a little outside the fenders.
but are we talking about a lowered car?
Old Aug 8, 2004 | 07:50 PM
Default Re: offset...+30? is that ok? (BolivianDc2)
exactly, thats what i'm talking about...thanks
well my **** is hella slammed...
Old Aug 12, 2004 | 10:56 PM
Ri5e's Avatar
hmm...+20 offset on the red teg
Old Aug 13, 2004 | 02:17 AM
ilovemyhonda's Avatar
Default Re: offset...+30? is that ok? (BG Boost)
that's nice
Old Aug 13, 2004 | 06:16 AM
Cosworth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BG Boost &raquo;</TD></TR><TR><TD CLASS="quote">
hmm...+20 offset on the red teg </TD></TR></TABLE>
you can't directly compare LS/RS/GS-R to that of an ITR. ITR has a bit wider track (5mm) in the rear to start with. So, +20mm would stick out a wee-bit more than your picture. To some it's not a big difference, but to me it makes a whole lot of difference.
GSR:
Front Track: 1475 mm / 58.1 in
Rear Track: 1470 mm /57.8 in
ITR:
Front Track 1480 mm / 58.3 in
Rear Track 1475 mm / 58.1 in
Old Aug 13, 2004 | 06:43 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Assuming an ITR with stock ride height:
35mm offset, the tires will stick out a liiittle bit with 205 tires. It should not have any rubbing.
30mm offset would look really funky/ugly, unless the car is lowered and with -2 or -3 of camber.
Old Aug 16, 2004 | 09:31 PM
andrew dc's Avatar
Default Re: (Wai)
on that note, would there ever be caliper clearance issues? I always thought hondas needed to be between +45-35 offset. So we can go all the way down to +20
Old Aug 17, 2004 | 05:05 AM
Wai's Avatar
Wai
Default Re: (andrew ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrew ef &raquo;</TD></TR><TR><TD CLASS="quote">on that note, would there ever be caliper clearance issues? I always thought hondas needed to be between +45-35 offset. So we can go all the way down to +20</TD></TR></TABLE>
The lower the + offset is, the spokes/center of the wheel are further away from the hub so you get MORE brake clearance.
Old Aug 17, 2004 | 05:10 AM
1GreyTeg's Avatar
Default Re: (Wai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">
The lower the + offset is, the spokes/center of the wheel are further away from the hub so you get MORE brake clearance.</TD></TR></TABLE>
But depending on how slammed and offset, he may have to roll the fenders.
That all seems to be for looks. To each his own.
Old Aug 17, 2004 | 06:21 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: (Wai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">Assuming an ITR with stock ride height:
30mm offset would look really funky/ugly, unless the car is lowered and with -2 or -3 of camber.</TD></TR></TABLE>
I'm agreeing w/Wai.
vart
Dec 26, 2004 07:41 PM
Eclypz
Nov 8, 2004 04:00 PM
rufridn
Nov 7, 2004 07:00 AM
1zach4
Aug 31, 2004 06:46 PM
JapSpec954
Aug 9, 2003 01:04 AM
