OEM JDM type R spark plugs
I'm a Jackass
Re: OEM JDM type R spark plugs (dajah_vue)
i just bought a 2000 JDM honda integra type r drivetran and planning to swap it in my crx....i took out the spark plugs and it was NGK R. is that usaully stock for it..... or is it a aftermarket spark plug. n-e ways any of you guys know where i can find the repair manaul book for my model. or is it ok to use the acura integra type r manaul nor the acura integra LS.
NGK part# BKR7EGP for OEM JDM ITR
JDM engines are higher compression than U.S. Version so therefore they come stock with # 7 heat range.
Re: OEM JDM type R spark plugs (jmk2888)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 »</TD></TR><TR><TD CLASS="quote">NGK part# BKR7EGP for OEM JDM ITR
JDM engines are higher compression than U.S. Version so therefore they come stock with # 7 heat range.</TD></TR></TABLE>
pretty sure usdm is heat range 7 as well
Re: OEM JDM type R spark plugs (tartje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje »</TD></TR><TR><TD CLASS="quote">98079-5714H (PFR7G-11)
for the 11.1:1 compression motors </TD></TR></TABLE>
For OEM JDM ITR, Honda used NGK Plantium.
Read here:
https://honda-tech.com/zerothread?id=278800
Read here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmk2888 »</TD></TR><TR><TD CLASS="quote">For OEM JDM ITR, Honda used NGK Plantium.
PFR7G-11 is the platinum.
P=Premium Platinum (Laser Platinum)
BKR7EGP is the G-Power Platinum, one step down.
Re: OEM JDM type R spark plugs (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt »</TD></TR><TR><TD CLASS="quote">
BKR7EGP is the G-Power Platinum, one step down.</TD></TR></TABLE>
thank you
thank you
I'm a Jackass
so any of you guys no where i could get a repair manual book for my JDM motor..... or a manual book for my model..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dajah_vue »</TD></TR><TR><TD CLASS="quote">so any of you guys no where i could get a repair manual book for my JDM motor..... or a manual book for my model.. </TD></TR></TABLE>
egay.com
egay.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dajah_vue »</TD></TR><TR><TD CLASS="quote">will the acura integra type r manual book be the same as the (JDM) honda integra type r. </TD></TR></TABLE>
Pretty much, but probably in English instead of Japanese.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dajah_vue »</TD></TR><TR><TD CLASS="quote">will the acura integra type r manual book be the same as the honda integra type r. </TD></TR></TABLE>
ask me some stuff about information and page numbers or whatever you want and i'll answer
the technical info will be different but the basics will probably be the same
I have been running PFR6G-11 plugs on my JDM Type R for 30k miles. How crucial is it that I get PFR7G-11 plugs? Also, where do you recommend getting them from?
http://www.acuraoemparts.com/delray/...1=&inputstate=
It says the NSX's use the PFR7G-11 plug. How can I be sure that a JDM Type R is supposed to use that as well?
Alternatively, from a Honda dealer you can get the S2000 plug: http://www.hondaautomotiveparts.com/...=IGNITION+COIL
They are PFR7G-11S plugs though. Is there any difference in the PFR7G-11 and the PFR7G-11S and which one is meant for the JDM Type R?
I just got finished doing a swap to a JDM B18C Type R in my DC2. I used NGK Iridiums because a friend recommended them, not sure how different they are from the platinums. If anyone is curious, I can post my experience with them once I put some miles on them
So can I use PFR7G-11S plugs in my JDM Type R, or only PFR7G-11?
When googling it, the only difference I found has to do with the addition of a stainless steel washer. I am not sure if this makes it only fit in S2000 motors or not. Please let me know, I want to make a purchase soon.
