O2 simulator
Old Sep 20, 2005 | 08:21 PM
Bbasso's Avatar
Default O2 simulator
PERRIN Performance™ O2 simulator, Anyone ever hear of this or use one?
http://hpautoworks.com/peo2si.html
Just asking...
Old Sep 20, 2005 | 08:25 PM
Mythias's Avatar
Default Re: O2 simulator (Bbasso)
IIRC, you will not have CEL, but you will have a readiness code. That may be an issue if you have emissions testing.
You can make one for just a few bucks.
Old Sep 20, 2005 | 08:26 PM
Ekasey's Avatar
Neat-o
its essentially a resisitor in a box
ecu wants to see .5V coming from the rear 02 sensor this takes the input voltage runs it through the proper resistor and puts it out to the ecu
k thanks
Old Sep 20, 2005 | 08:35 PM
KOALA YUMMIES's Avatar
Default Re: O2 simulator (Casey@Burns)
So its the same exact thing as those diagrams that have been floating around, I bought the resistors from radio shack a while ago but never got around to actually doing this. A friend of mine and I were talking about how you can just solder the resistors in line with the original 02 harness and ditch the PC board as well, and if you even wanted to solder them at the ECU.
Old Sep 20, 2005 | 09:04 PM
ZygSpeed's Avatar
My Mugen ECU works just fine in that respect!
Old Sep 21, 2005 | 05:04 AM
AssPenny's Avatar
Default Re: O2 simulator (zygspeed)
Hit up Ken/Black R. I believe he was making some plug-in and play versions for a decent price. If not, let me know, I have the diagram, but the colors aren't right. Also I believe somebody tried to make one and had to make a few changes to the resitiance. Try a search, its been covered multiple times.
Old Sep 21, 2005 | 09:18 AM
DC2fanboy's Avatar
Tin foiling the secondary also works well. You may get a "slow response" code once in a (long) while, but I believe the same thing occurs with the simulators.
Old Sep 21, 2005 | 10:28 AM
Chunty Butt Kevin's Avatar
we wrx people have those. its called a cel fix
Old Sep 21, 2005 | 11:00 AM
RaVAGE00's Avatar
New User
Default Re: (Chunty Butt Kevin)
Does anyone have any diagrams on how to make a home version.....
Old Sep 21, 2005 | 11:02 AM
AssPenny's Avatar
Default Re: (RaVAGE00)
Like I stated ealier, I don't believe the wire colors are correct. If we can get Black R in here, I think he knows the correct combinations.
Old Sep 21, 2005 | 11:03 AM
BAH AssPenny wins!!!!!!!!!!!!!!1 omfgz0r!
Old Sep 21, 2005 | 11:31 AM
TSAngry's Avatar
Default Re: (KOALA YUMMIES)
you can also try using an antifouler. they sell it at kragens. its a metal bung that you screw into the existing bung on your cat. then you screw in your o2 sensor into the antifouler. the antifouler bung positions your o2 sensor farther out from the inside of the cat. that way the ecu thinks that the cat is still working. it worked on my friends car.
Old Sep 21, 2005 | 11:41 AM
Black R's Avatar
25 Year Member
Default Re: (TS-Angry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TS-Angry &raquo;</TD></TR><TR><TD CLASS="quote">you can also try using an antifouler. they sell it at kragens. its a metal bung that you screw into the existing bung on your cat. then you screw in your o2 sensor into the antifouler. the antifouler bung positions your o2 sensor farther out from the inside of the cat. that way the ecu thinks that the cat is still working. it worked on my friends car. </TD></TR></TABLE>
.....that is essentially what the godspeed testpipe has.
I just make a plug and play version of what asspenny posted.
They're a pain in the *** to make, but for you Bbasso I'll hook it up.
Old Sep 21, 2005 | 11:48 AM
pyromaster's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
They're a pain in the *** to make, but for you Bbasso I'll hook it up. </TD></TR></TABLE>
while you're at it, mind hooking me up too? I've got to be close to burning out my CEL light and I need it to be functional to pass GA emissions. If it's too big a PITA nevermind
Old Sep 21, 2005 | 12:16 PM
Black R's Avatar
25 Year Member
I'll hook you up too Jeff.
Old Sep 22, 2005 | 04:02 AM
RaVAGE00's Avatar
New User
It connects inline with your o2 sensor. I have yet to try it on a honda or
acura. They said it would only work on Mazda and Mitsubishi but we have
tried it on a bunch of nissans and worked w/o any problems. I assume its
just a general 02sim.
----- Original Message -----
hpautoworks@***.net
baulum
Engine Management and Tuning
Jan 14, 2010 11:14 PM
94DCTeg
Jun 21, 2008 01:00 PM
98vtec
Jan 17, 2008 04:00 PM
turbodan4
Nov 7, 2006 04:28 AM
