need help . is it da msd ignistion?
Hey I have type r b18c5 I just finished takin out my turbo . I got p28 chiped bak to stock. But now car stars den turns off like rite away. And if u gas it catches only sumtimes and still turns off. The only thin I have still hooked up is the msd ignition }he 2step box and boost gauge. . So does anyone noe wut could b the problem?
Re: need help . is it da msd ignistion?
Hey so lemme git it str8 aint u gots a turbo buts u tooks it off and chped p28 and it dont start. if u gas it sometimes will catches its and turns it off. The only thin still hooked up is da msd ignistions sand b00st gages and 2steps on 2. need help findins neones thats wood noe wut da problm kood b.
Last edited by 98ITR747; 08-20-2009 at 11:03 AM. Reason: fixor'd a few spellin ers.
I did not know that the ITR used a P28 ECU.
Seriously, I suspect that your chip may not be 'stock'. I assume that you are running stock injectors now, since a stock program is not going to run properly with bigger injectors. For the love of Mike, please learn to use the English language properly.
hatchinprogress
10-10-2004 08:19 AM
93hatchboosted
07-10-2004 01:51 PM
MAD SCIENTIST
04-25-2003 09:04 PM
yellowbulbs
06-19-2001 02:42 PM
