Need Help between CTR and ITR
Old Jan 21, 2003 | 08:55 PM
CivicCXG's Avatar
Default Need Help between CTR and ITR
just wondering if CTR block is the same height as the ITR...........if same as ITR than is it destroked to 1.6? Thanks
Old Jan 21, 2003 | 09:01 PM
uNF$@#!'s Avatar
Default Re: Need Help between CTR and ITR (CivicCXG)
its not the same motor, if thats what your trying to get at.
Old Jan 21, 2003 | 09:19 PM
Brasspremier's Avatar
Default Re: Need Help between CTR and ITR (Soup ****)
hes asking height. i'm sure hes aware they are different engines
Old Jan 21, 2003 | 09:22 PM
Junior_r's Avatar
yes and yes
Old Jan 21, 2003 | 09:28 PM
CivicCXG's Avatar
Default Re: Need Help between CTR and ITR (Junior R)
I know it's B16B and B18C but just wondering what's the difference with the B16B. I know the bore and stroke is the same but I think the rod length is a little bit longer than that regular B16A. If I change the crank on the B16B to ITR can I get a 1.8 out of it?
Old Jan 21, 2003 | 10:06 PM
Unlimited's Avatar
New User
Mr.Spoon himself said the first thing he'd do to the CTR engine would be to bore it out to 1.8l. does that answer your question?
However, that 1.8 liter B16B would still maintain its superior R/S ratio over the B18C5.
Just how would the stroked out 16B have a superior R/S over the 18C/C5? Particularly when you will be using the same CRANK and RODS from the 18C/C5?
The block is the same....16B = 18C
what you end up having is 18C + PCT pistons (or whatever pistons you choose to use) in a block with a STAMP of a 16B
https://honda-tech.com/zerothread?id=377714
airmaxbri
Oct 5, 2007 05:38 AM
spoonfed95
Feb 18, 2006 01:51 PM
Rev2 9K
Sep 17, 2005 10:43 AM
92WhiteEG
Sep 11, 2003 01:44 PM
