need help ASAP!!!
Old Sep 10, 2002 | 06:49 PM
stRtypR25's Avatar
Default need help ASAP!!!
i was driving home from work and all of a sudden my battery light came up.
WTF is the prob?
Old Sep 10, 2002 | 06:55 PM
uNF$@#!'s Avatar
Default Re: need help ASAP!!! (stRtypR25)
your battery isnt holding charge anymore ?
Old Sep 10, 2002 | 06:58 PM
rs's Avatar
rs
We need more details then that....
How old is the battery?
Does your car start (tomorrow)?
Wires are all connected?
RTW DC2R's Avatar
Default Re: need help ASAP!!! (Soup ****)
sounds like you need more battery fluid
Old Sep 10, 2002 | 07:00 PM
stRtypR25's Avatar
Default Re: need help ASAP!!! (Type Rizzle Fo' Shizzle)
yea the car turns on. i dont know exactly how old the battery is, it came with the car when i bought it a year ago. i thing i did notice was that when i put my windows up, they moved really slow(i dunno if this has anything to do with the prob).
TIA
Old Sep 10, 2002 | 07:01 PM
uNF$@#!'s Avatar
just replace your battery then.
Old Sep 10, 2002 | 07:10 PM
lotus's Avatar
New User
You need a digital volt /ohm meter ( DVOM ) to test your charging system... the light is indicating insufficient charge from your alternator..
If you don't have one then take the car to a garage to have them check it..
Shouldn't cost more than about 15 bucks for the check, and that will tell you what you need to replace...
If you have a DVOM then put it on your battery and start your car.. Voltage should be about 13.5 to 14.5. Turn on your lights, radio, wipers etc to put a load on the system.. Voltage should be still within that range.. Any higher or lower the alternator is suspect.. make sure the belt is tight... anything in that range then the battery is suspect.. Clean the terminals well and try using the car again to see if the battery charges.. Make sure the water level is up..
DON'T ADD ACID! Could cause an explosive reaction in an old battery. With the car turned off the battery should normally read about 12.8 to 13.5 volts.. Have someone hit the starter and watch where the battery voltage drops to.. anything below 12 volts means the battery is again suspect..
Hope this helps.. this is just general info..
You know I wouldn't have to edit this so much if I could bloody spell
[Modified by lotus, 4:12 AM 9/11/2002]
[Modified by lotus, 4:13 AM 9/11/2002]
[Modified by lotus, 4:14 AM 9/11/2002]
Old Sep 10, 2002 | 07:11 PM
stRtypR25's Avatar
alright thanks for the help
Old Sep 10, 2002 | 08:15 PM
MR. ARIZONA's Avatar
Take it to autozone, they'll run a FREE test for you...
Old Sep 10, 2002 | 11:21 PM
sgT's Avatar
sgT
Default Re: need help ASAP!!! (QUICKTEG)
possibly the alternator/charging system
Old Sep 11, 2002 | 05:31 AM
Drag R's Avatar
chek to make sure the alternator belt is still on......
PoisonRitualz
Oct 24, 2018 02:20 PM
ef9one6
Apr 17, 2007 07:31 PM
biggdogg
18
Nov 26, 2003 06:32 AM
deviant94ex
Apr 27, 2003 11:17 AM
W.Zero
Jan 28, 2003 11:43 AM
