Narrowing down my problems.....
Old Jun 14, 2004 | 07:22 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Narrowing down my problems.....
As many of you know, I've had a lot of recent problems with my R that I couldn't figure out. Many of you stated alternator, some stated ignitor, some said battery, others said relay and ECU.... The car just randomly dies...
I ordered a new ignitor from Len and a new alternator from Bert-O I replaced the battery last week and the car died 1.5 days later. After sitting for 4 hours, it fired back up and I was able to make it back home which sort of indicated ignitor. Tonight I had some free time, so with the help of a good friend, I replaced the ignitor and recharged the a/c thanks to new lines from DavidNYC Everything went smoothly. Car started beautifully, recharged the a/c - nice and cold in the ******* Florida heat. Lights working fine. I hit the gas and the lights go brighter indicating the alternator is charging fine. Now the test of death. With the car running, I took the positive cable off the battery and she still ran. Turned the lights on and she still ran fine. Turned the a/c on and it died immediately. So does this single out the alternator? how long with the car run without having an alternator charging the motor?
Marc ---> who was , but is still
Old Jun 14, 2004 | 07:29 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: Narrowing down my problems..... (RealTypeR)
I am guessing the alternator.
Yo realtor just find someone with a DVOM or analog volt ohm meter and see what the voltage is when the car is running. holler
I think they do tests at autozone/advanvce places for your alternator also.
Old Jun 14, 2004 | 08:05 PM
Bbasso's Avatar
see if you have a short somewhere by, taking off the postive cable and putting a test light between the cable and the battery, if it lights up you have a short.
Other wise I'm stumped.
Old Jun 15, 2004 | 05:41 AM
Default Re: Narrowing down my problems..... (Bbasso)
Will try that Rob.
Old Jun 15, 2004 | 05:47 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Narrowing down my problems..... (v-attack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote">I think they do tests at autozone/advanvce places for your alternator also.</TD></TR></TABLE>
Just a data point - Autozone sold me three bad starters in a row for my Scout. I made them bench-test them each and every time, and while they checked out on the bench, they wouldn't even begin to turn the Scout over.
Finally punted and took the truck to a shop. Bad starter. Told them I had just replaced it with an Autozone unit, and they said "that's your problem, their rebuilds suck. Go to Napa and bring one back from there, we'll charge you less."
Got Autozone to reimburse me for the repair bill
Cliffs: Don't trust Autozone's test. Just because they claim it's ok doesn't mean it really is.
Old Jun 15, 2004 | 06:05 AM
Default Re: Narrowing down my problems..... (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">
Cliffs: Don't trust Autozone's test. Just because they claim it's ok doesn't mean it really is.</TD></TR></TABLE>
I couldn't agree more.
Old Jun 15, 2004 | 09:05 AM
gblaue's Avatar
The fact the car died when you turned on the AC doesn't surprise me in the least. The Type R altenator is, well, wimpy to say the least. AC is a huge current draw on the battery, when it is connected. The altenator cannot source that kind of current. The purpose of the altenator is to charge and assist the battery, not to run the vehicle. I think your going down the wrong path, or your on the right path but for the wrong reason.
Old Jun 15, 2004 | 10:27 AM
Default Re: Narrowing down my problems..... (00ITR#756)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ITR#756 &raquo;</TD></TR><TR><TD CLASS="quote"> I think your going down the wrong path, or your on the right path but for the wrong reason.</TD></TR></TABLE>
I don't quite understand what you mean....
Old Jun 15, 2004 | 12:25 PM
RockstarJR's Avatar
Broke *** R... 4 life
Old Jun 15, 2004 | 01:07 PM
Big Money D's Avatar
Default Re: Narrowing down my problems..... (RockstarJR)
at least the back seats don't smell....
Old Jun 15, 2004 | 01:45 PM
ILUVTEC's Avatar
Default Re: Narrowing down my problems..... (Big Money D)
once again, D or myslef to the rescue
Old Jun 15, 2004 | 04:53 PM
mikehonda's Avatar
OK, A/C does not draw THAT much current to kill the motor. The fans comming on do however. Are we sure the A/C compressor isn't siezed? At normal operating temp. does the idle rise when the lights are turned on (IAC valve)? What were the results of the charging system load test? You did that test right? Have you considered your ignition switch could be at fault, jiggle the key with the engine running and see if it dies. The right front shock tower (pass. side) has several vital connectors/wires, make absolute sure these are making positive connection. This WILL cause the car to die for "no reason" Feel free to IM me, I've got lots of tips on this problem...
mikehonda: who up to 47 fixed Honda buy-back cars
wspencer5
Honda Civic (2001 - 2005)
Jan 3, 2015 02:10 PM
medjosh6
Jul 21, 2009 05:03 PM
lawlerlaw
Jan 8, 2005 02:12 AM
in4mation
Dec 15, 2004 08:10 AM
L4NDO
May 22, 2003 06:30 PM
