my Vtec kicks in @ 6000.. is it something wrong?
Old Jun 17, 2006 | 05:55 PM
PaChiLa Leader's Avatar
Default my Vtec kicks in @ 6000.. is it something wrong?
i have a 00 ITR and my Vtec kicks in @ 6k, is it normal? i just read it somewhere that the stock Vtec point should be @ 5700 not @ 6k like mine..
is it something wrong with my car?
Old Jun 17, 2006 | 06:03 PM
Mires's Avatar
Default Re: my Vtec kicks in @ 6000.. is it something wrong? (PaChiLa Leader)
Im sure its fine. The stock tach is usually a little bit off. I've heard it also depends on how hard the throttle is pressed but that might have been smoke blown up my ***.
Old Jun 17, 2006 | 06:14 PM
JjuuN R's Avatar
Default Re: my Vtec kicks in @ 6000.. is it something wrong? (Mires)
Mires is probably right about the tach being off a bit, if it makes you feel any better mine is SET to 6000rpm, shifting at 9800rpm
Old Jun 17, 2006 | 06:33 PM
Default Re: my Vtec kicks in @ 6000.. is it something wrong? (JUN.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">Mires is probably right about the tach being off a bit, if it makes you feel any better mine is SET to 6000rpm, shifting at 9800rpm </TD></TR></TABLE>
Crazyyy... oh yeah i remember you now jun.. saw you post your teg a month ago.. nice Yellow R..
Old Jun 17, 2006 | 07:09 PM
itr1244's Avatar
i wanna see some action of this thing going
mine will be set at 6100 sometime soon but only can rev to 9000 rpm tho
Old Jun 17, 2006 | 08:00 PM
JjuuN R's Avatar
Default Re: my Vtec kicks in @ 6000.. is it something wrong? (itr1244)
don't get me wrong, it's not like i drive around all day every day pushing my car to 9800rpm, but it's possible
Old Jun 17, 2006 | 08:58 PM
Justin Klemgold's Avatar
VTEC engagement depends on five things....
Temp - normal operating temp needed
Throttle Position
Vehicle speed - car must be in motion
RPM - Targeted value
Oil pressure
Old Jun 17, 2006 | 09:06 PM
Default Re: (Justin Klemgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">VTEC engagement depends on five things....
Throttle Position
Oil pressure</TD></TR></TABLE>
it was under Normal operating temp, Full Throttle position, 3rd Gear @ 6000 RPM, oil changed the same morning.. and Vtec engaged @ 6000 that's why i am asking.. but most of ppl told me it's normal so i guess it's fine..
Old Jun 17, 2006 | 10:01 PM
Yeah it's fine....dont' worry about it.
Old Jun 18, 2006 | 12:02 AM
DutchITR1689's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaChiLa Leader &raquo;</TD></TR><TR><TD CLASS="quote">i have a 00 ITR and my Vtec kicks in @ 6k, is it normal? i just read it somewhere that the stock Vtec point should be @ 5700 not @ 6k like mine..
is it something wrong with my car?</TD></TR></TABLE>
Now you know that 6000 rpm on your tach = 5700 rpm in real....
Old Jun 18, 2006 | 12:19 AM
Default Re: my Vtec kicks in @ 6000.. is it something wrong? (DutchITR1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">
Now you know that 6000 rpm on your tach = 5700 rpm in real....</TD></TR></TABLE>
YES I HAVE, but why is it off? i mean is it only mine or same as everybody else?
Old Jun 18, 2006 | 12:37 AM
92TypeR's Avatar
FSAE
Everyone's tach is like that, don't get paranoid
Although its neet, you can tell your friends your car revvs to 9k, because of the error with the tach reading, your 8500rpm fuel cut appears to be a 9k fuel cut
Old Jun 18, 2006 | 05:09 PM
mugenracer's Avatar
Theyre all off, mine is off nearly 400rpm at an 8800rpm. I have a shift light wired into an r-spec vtec controller and the tach shows 9200rpm when the shift light is set for 8800rpm
Old Jun 18, 2006 | 08:15 PM
-tc-'s Avatar
Default Re: (mugenracer)
yea there all off, i had a vafc2 which is supposed to read the correct rpms, as the stock tach would go higher the more unaccurate it gets, like idleing it would only be like 50 or so off to what the vafc2 was reading, by redline its like 400 off.
Old Jun 18, 2006 | 08:23 PM
Default Re: (trc_R)
i dont' know about your guys.. but i have never hit the Redline on my R engine yet so i don't know where exactly it goes up to~ guess i might try it when my shift lights are install..~
Old Jun 18, 2006 | 08:58 PM
picos's Avatar
Default Re: (PaChiLa Leader)
you depending on your shift lights?
Old Jun 18, 2006 | 09:01 PM
Default Re: (picos)
if the tach is all off.. the only thing can reads correctly would be the shift light, no?
Old Jun 18, 2006 | 09:23 PM
picos's Avatar
ah of course, good point
Old Jun 18, 2006 | 09:30 PM
Default Re: (picos)
Guys i have another question, what's the Compression of a stock ITR motor should get?? i did mine CP test a couple weeks ago and got 215 cross all 4 is it good or bad?? the engine suppose only have 30k km on it.. so its very low
i did some search and see others have 250 cross.. so is my 215 normal or no? my mechanic told me it's very good @ 215 but after reading other posts.. i am not too sure now~
Old Jun 18, 2006 | 09:43 PM
hybrider's Avatar
215 on a B18C5 across the board represents good numbers and a healthy engine. As long as there is a minimal variation between each cylinders numbers (as here) you're fine.
Modified by hybrider at 1:20 AM 6/19/2006
Old Jun 19, 2006 | 02:17 AM
rzz's Avatar
rzz
hey lawrence, this is ray
my friend's old itr has the same problem as your itr (the vtec shift over at 6k rpm or so)
but i don't think it is a problem because most stock tachs are slightly off
even my tach is off when i hit close to redline (it hits up to 9100rpm on the tach but the power FC shows it is 8500 to 8700 rpm)
Old Jun 19, 2006 | 09:29 AM
H-PIMP's Avatar
Default Re: (rzz)
Probably just error in the tach.
Hatchman98
Jun 7, 2007 01:45 PM
dgmorr
Feb 15, 2006 10:21 AM
Mefain
Jul 6, 2004 08:37 PM
NightHawkC5
Feb 12, 2003 11:51 AM
JDM 007
May 27, 2002 02:02 PM
