MSD ignition.......
Old Aug 17, 2005 | 07:21 PM
digital sol's Avatar
Default MSD ignition.......
any of you running msd digital 6 or similar msd systems and notice a power gain? What are msd components are you running and how was your experience with them?
i was thinking of running the digital 6, and the ss blaster coil w/ msdwires
Modified by digital sol at 8:49 PM 8/17/2005
Old Aug 17, 2005 | 09:08 PM
cambopheonix56's Avatar
Default Re: MSD ignition....... (digital sol)
what are your mods? because if its not hevily modified, the oem ignition will be just fine. And correct me if i am wrong, but you wont see any gains.
Old Aug 18, 2005 | 04:06 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: MSD ignition....... (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">what are your mods? because if its not hevily modified, the oem ignition will be just fine. And correct me if i am wrong, but you wont see any gains.</TD></TR></TABLE>
I agree, if your not putting out alot of power I think the stock ignition is plenty. But I do have a msd ignition on my car if you wanna buy it.
Old Aug 18, 2005 | 04:10 AM
Bbasso's Avatar
Put your money else where...
Many people have tried and have shown little to no gains, But did have headaches
Old Aug 18, 2005 | 04:21 AM
PM-Performance's Avatar
Default Re: MSD ignition....... (Bbasso)
not worth it. YOu wont notice the difference at all.
Old Aug 18, 2005 | 12:00 PM
Default Re: MSD ignition....... (itr206)
1 of the reasons why i need msd is because for some reason or another hondata will not accept any rev limiter, the tuner has tried everything for some reason my car has 0 rev limiter, hondata says its set for 9k, then changed it to 8.4k but either way once its in there is 0 rev limiter....
figured i might as well just get msd digital 6, rev limiter, rev launch control, ect ect....tired of trying **** to fix the problem, msd would fix it
Old Aug 18, 2005 | 02:08 PM
MSD 2satep does work much better then Hondata thats for sure.
Tell him to set the rev limits in the software and not with the clutch switch ****. Those are junk .
I had probs with them too.
Old Aug 18, 2005 | 02:39 PM
you talking about within the hondata?
he spent like an hour playing with it and nothing seemed to work, hed change it, pull the chip install and my car would free rev past 9k
then when he put it back into the computer it showed that the rev limiter was changed to 8400 but the car's rev's wont cut-out
tired of messing with it so i figured id pick up a msd digital 6 and eliminate the problem, its going to be built/boosted over winter anyways, msd might come in handy later down the road.....it would solve my problem for now at least
Old Aug 18, 2005 | 02:41 PM
TypeR15's Avatar
i have the msd 6al with 2step and SS blaster coil...i love it works fine
Old Aug 19, 2005 | 02:26 AM
theres a good chance your tuner doesn't know what he is doing then or something is fucked up.
I never had a problem setting it in the software.
I only had problems when ******* with the clutch switch set up to change on the fly. I would change one thing and it would change all kinds of other limits. So I got pissed and never used it again
Old Aug 19, 2005 | 06:33 AM
200cs's Avatar
I put a Jacob's set-up on mine when it was N/A. I did notice a power gain. Multiple sparks per combustion sequence are better than one...Now it is a nice compliment to a turbo.
Old Aug 19, 2005 | 07:27 AM
Default Re: MSD ignition....... (200cs)
hes only been a certified hondata tuner for about a year, tuned my car real good though and is only like 1 of 2 certified hondata tuners in the area
he thinks it might have to do with my hondata being 2.5 and his software being 3.0 possibly......
think im just gonna get the msd and use it's rev limiter setting's
Old Aug 19, 2005 | 07:44 AM
it could be. I used 2.5 and my tuner used the new stuff and it always acted wierd when he was tuning, but once we converted the maps it alwyas worked fine
Old Aug 19, 2005 | 01:21 PM
HYREV2NR's Avatar
I had full MSD SCI box & external coil. It's now for sale cause I went back to stock ignition & noticed no difference. They say it works great if your boosting 15 to 20 psi or more. I'll take 200 for the MSD box & coil.
97tegblk
Sep 11, 2007 07:03 PM
budget
Apr 17, 2005 09:17 PM
SpdFrk
Aug 9, 2003 08:32 AM
1.8T_EG
May 14, 2003 09:45 AM
