Mod question
Old May 6, 2007 | 07:25 PM
Morty's Avatar
Default Mod question
Hey guys new to type R...just got mine a few weeks ago
my car only has CAI and was wondering this:
should i do internals..(was insterested in Spoon cams) or exhaust
your opinions would be great
thanks deryk.
Old May 6, 2007 | 07:32 PM
migs's Avatar
Default Re: Mod question (Morty)
Morty, welcome aboard. SEARCH.
Old May 6, 2007 | 07:48 PM
Morty's Avatar
Default Re: Mod question (migs)
I have been on the search for the last two weeks....and read a lot.... but every situation is different.
Old May 6, 2007 | 07:50 PM
330R's Avatar
Be different - leave it alone!
GO-FIGHT-KILL's Avatar
What are you going for? I'd start with bolt ons, and if you desire more power, go from there... But you can get a good amount of power from intake, header, exhaust, and a good tune. I've heard of well into 190whp+ with bolt ons and tuning.
Old May 6, 2007 | 07:55 PM
Morty's Avatar
Default Re: (GO-FIGHT-KILL)
First off....fastest responses ever thank you.
Spoon cams are a lot cheaper then full exhaust...but if i am going to see a difference with exhaust as well then maybe i should start from there...
what i am looking for in the end is 220-230 whp would be nice
Old May 6, 2007 | 08:54 PM
all-mtr-teg's Avatar
Default Re: (Morty)
i don't think 220-230 whp is achievable with just bolt ons, unless you go turbo, supercharger or nitrous.
Old May 6, 2007 | 08:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morty &raquo;</TD></TR><TR><TD CLASS="quote">First off....fastest responses ever thank you.
what i am looking for in the end is 220-230 whp would be nice</TD></TR></TABLE>
High quality bolt ons and a nice head package with higher CR would do that... I'd recommend:
-Mugen Intake
-ImportBuilders ported and polished Type-R intake
-RPM Services 72-70mm throttle body
-Mild port work to the head
-JUN valvetrain (Springs/retainers)
-JUN-III cams
-P73-00 Integra Type-R pistons
-Single layer headgasket
-SMS-P header
-SMS-P 2.5" exhaust
-440cc injectors
-Some form of GOOD fuel management, and a good tune
That would yield 220-230whp with a good tune. Pair that with a tighter final drive (ATS 4.928/5.077, JDM ITR 4.785), and damn, you're talking about a fun car.
Old May 6, 2007 | 09:00 PM
Default Re: (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">i don't think 220-230 whp is achievable with just bolt ons, unless you go turbo, supercharger or nitrous.</TD></TR></TABLE>
... Stop.
Old May 6, 2007 | 09:49 PM
Morty's Avatar
Yah NA is my style thanks for the suggestions...will start with basics and go from there.
^ Good call. A bit more advice, RESEARCH EVERYTHING YOU CONSIDER THOROUGHLY BEFORE YOU BUY.
Old May 6, 2007 | 09:52 PM
Morty's Avatar
yah i have gone thrugh similar things with the H series motors...it just seems that exhaust is a lot more important to B series. I have looked into Spoon cams seems good for street...JunIII seems a bit agressive but then 220whp is a bit much to expect aswell
Old May 6, 2007 | 10:02 PM
JUN-IIIs are fine for street use. I've heard of 215-220whp on a completely stock Type-R bottom end/head/intake system with JUN-III headpackage.
Old May 6, 2007 | 10:17 PM
Morty's Avatar
Wow thats impressive...im bassically looking for a little more power without going turbo or working on the bottom end
your info has been great thanks...will look through all the cams before deciding thanks.
Old May 6, 2007 | 10:22 PM
No problem.
Just remember, that most aggressive cams react better with a higher CR (Typically around 11.5:1+), so you'll be missing out a bit on stock USDM 10.6:1CR. At the very least, I'd go with P73-00 JDM Integra Type-R pistons with a single layer headgasket (Which would put you in optimal CR range for aggressive cams), and you'll create much more power over stock USDM bottom end.
That's my advice, at least look into doing that to the bottom end at the very least.
outlawzsouljah
Mar 21, 2010 04:18 PM
bigsnorlax
Apr 2, 2009 10:11 AM
konartis
Mar 21, 2008 03:28 PM
tomlinson619
17
Aug 25, 2006 03:21 AM
CRrex
26
May 16, 2002 12:56 AM
